Very Basic
Sorry to ask such a basic question, but I’m very new to the MikroTik device.
I have a RouterBOARD 951G 2HnD and all I want to do is separate the Ethernet network from the Wi-Fi network e.g. have a guest network on the Wi-Fi, what is the easiest way to do this if its possible please?
Thank you.
If using the default config, just take the wireless interface out of the bridge and assign a new subnet to it and create a DHCP server on the wlan interface.
Thanks for your reply.
Under bridge ports, I have removed the wireless interface.
I created a DHCP server under interface wlan1
and under addresses I added the network 192.168.0.0 subnet 192.168.0.1/24
I still seem to be stuck with only one DHCP range though for the LAN/WLAN
Again sorry for been just a noob.
Thank you.
Remove the DHCP server you created and use the “DHCP Setup” button on the DHCP Server window. It will create the pool and everything for you.
Thank you, that worked :slight_smile:
