Very challenging problem
Hello, I hope somebody can give me a solution
A lightning problem made the POE interface unusable in a RB532, so now I am able only to access from ether2.
I formated NAND to install the upgrade mikrotik version but I can not use netinstall because the RB try to boot from ether0 that is not working.
The board is working fine because I could install dd-wwrt in a flash but I would like to use mikrotik in that board.
So the challenge is the next: What can I do if i can not use netinstall and the NAND is formated?
That board will haunt your network forever. DUMP IT!
You should have it repaired.
I had a RB511 that got a little to much power from one of those bright white flashes in the sky and to my surprise the POE port stopped working. LOL The charge for repair was only $29.00 US
