Very Good performence report!!
**I 'am very pleased to announce to all MT Os user a very good perfomence we get this week.
My company has got since two days ago the longest and fastest wireless link in Morocco: 20MB over 60KM PTP link!!.
Link is made of 2 RB500 MB with MT v 2.9.27 with nstreme-Dual on 5.8Ghz with 32 Dbi parabolic antenna from ITelite.
Thanks to Mikrotik Team!! Thanks very very much!!!**
Wow that is fantastic! What wireless cards are you using?
Congrats :slight_smile:
Link is made of 2 RB500 MB with MT > v 2.9.27 > with nstreme-Dual on 5.8Ghz with 32 Dbi parabolic antenna from ITelite.
But, your OS version…is it 2.8.27 or 2.9.7??
What radio cards are you using on that link?
more likely v2.9.7 because you can’t run v2.8.x on the RB500 :wink:
Wireless Card are four AR5414.
Soft is indeed V 2.9.7
By the way, after building the link we noticed a small problem and discovered the solution.
Problem:
If you try to make a bandwidth test on your soft or try to transfert a very huge file you may enconter a CPU overload and have no connection anymore over link.
Ping will not being possible anymore but Nstreme status will still being connected=yes.
Nstreme connection but no ping!
Solution:
You just have to disable and then enable your Nstreme interface on each side.
To atomate this just NetWatch and add at each side the othe device to be watched.
And then add these simlpe commands line for “On Down” status:
/interface wireless disable nstreme-dual disable nstreme1
/interface wireless enable nstreme-dual enable nstreme1
Do this on each side.
Hope this will help!
please post your dual-nstreme configuration. Try to set the framer-policy to none or lower the framer-limit to 2000.
