Hello, I am running some mikrotik routers with sstp server. I have two different situations, both with about 20-30 sstp clients (mikrotik 751); I get in both routers 100% cpu usage; this is not really a problem because it is responsive and gives good speed in sstp tunnels.
what do you need to debug this properly? I am not using an encryption-enabled profile.
edit: host is rb1100ah, I have also tried with x86 and inside metarouter, I get the same results.
What is the total encrypted traffic you are pushing? RB1000 with 200ish clients and about 40-50mbit of traffic pushes 25-30% cpu. I can see an RB1200 sweating with 1/2 that traffic.
Same problem here,
RB433, ROS 5.19, ~60 SSTP connections and constant 100% CPU usage. ROS responds quite well and almost no disconnecting was reported, though.
Clients are pushing about 500 bytes each 5 seconds, so there’s almost no traffic. With 5.12 from which I updated, CPU usage was around 15%.
Unfortunatelly have same problem with 5.20 - 100% cpu load mostly caused from ppp when sstp server active.
After restart sstp server it is ok until next sstp login.
I have the exact same issue on a RB1100AH with 6/7 clients. ROS 5.19 AND ROS 5.20
MT confirm its a bug and will be fixed next release. Can you get away with using L2TP/PPTP? We have to use SSTP because one of our cable providers blocks the other 2!
