Very high sector writes
Hi All: I’m running RouterOS 6.43.16 (long-term) on RB751g-2HnD and I’m seeing more than 7000 sector writes per day, I’ve opened webfig and checked the System->Resources menu and I can see how it writes 32 sectors every 6 minutes, approximately. Not only that, it almost reached 400000 sector writes after only 30 days last month, which I think it might be excessive, as nothing is supposed to be writing to disk at all. Just in case, I reset the router to default configuration and disabled DHCP writes to disk, there are no graphs running and logging is to memory only, but anyway the 32 writes every 6 minutes continue to happen, with over 7000 write after just 24 hours. This is my configuration in case anyone sees what could be causing this, unless it might be a bug.
add admin-mac=D4:CA:6D:51:FB:51 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX distance=indoors frequency=auto ht-supported-mcs=\
    mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15 mode=ap-bridge ssid=MikroTik-51FB55 wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.8.21-192.168.8.100
add address-pool=dhcp disabled=no interface=bridge lease-time=1d name=defconf
/tool user-manager customer
set admin access=own-routers,own-users,own-profiles,own-limits,config-payment-gw
add address=192.168.8.1/24 comment=defconf interface=ether2 network=192.168.8.0
/ip cloud
set update-time=no
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
/ip dhcp-server config
set store-leases-disk=never
/ip dhcp-server lease
add address=192.168.8.4 client-id=1:40:8d:5c:96:c1:24 mac-address=40:8D:5C:96:C1:24 server=defconf
add address=192.168.8.0/24 comment=defconf gateway=192.168.8.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.8.1 name=router.lan
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/system clock
set time-zone-name=America/Argentina/Salta
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set bridge disabled=yes display-time=5s
set wlan1 disabled=yes display-time=5s
set ether1 disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set ether3 disabled=yes display-time=5s
set ether4 disabled=yes display-time=5s
set ether5 disabled=yes display-time=5s
/system logging
add topics=debug
/system package update
set channel=long-term
/system watchdog
set watchdog-timer=no
/tool graphing
set store-every=24hours
/tool mac-server
/tool mac-server mac-winbox
/tool user-manager database
set db-path=user-manager
My guess: user manager … try to attach an USB flash disk and configure user manager to store its database to USB stick.
Thanks @mkx for your reply.
I have disabled user-manager package, as I don’t need it. I rebooted the router and will check again after a couple of hours to see if the writes have stopped.
Do you happen to see anything else that could be a cause for writes? User manager has been always enabled, but never used, and this write frequency just increased in the last couple of months, it was not like this before.
Indeed it seems it is not user-manager, or at least not only that. The router has been running for less than an hour and there are already 650 writes logged.
Many DHCP leases? Try:
/ip dhcp-server config set store-leases-disk=never
Edit: I see you have this already, so it must be something else…
I wonder if this setting
really disables writing to flash. Try to set it to something like 6h and see if it makes any difference.
I will try changing the setting. I thought that store-leases-disk=never was the way to go to avoid leases being written to disk, but I will try other setting. In any case, there are only 5 leases and the lease time is 1 day, so the refresh frequency is really low, once every 12 hours for just 5 leases. The router has been running for 4 hours and it already has more than 2000 sector writes.
It should … but there’s always room for some bugs :wink:
Well I changed the setting to store the leases every 24 hours, but the writes continue to raise. The router has been running for 12 hours and there are more than 4000 writes already. I don’t know what else to check or do, in less than 2 months there have been more than 1 million writes. I think that is definitely excessive.
Router has been running for 36 hours and there are more than 20000 sector writes. I don’t know what else to do. Should I contact support? I don’t have a support contract or anything like that.
As you have already tried a reset to default configuration, I would try to export (not backup) the configuration into a file, download the file to PC, netinstall the router, and check again with default configuration. If the ghost writes stop appearing, I’d re-import the configuration, otherwise I’d use some other RouterOS release (e.g. 6.43.15, as 6.43.16 only fixes some 60 GHz related issue).
support@mikrotik.com does accept information about well-documented real bugs even without a support contract, but they cannot deal with “how do I change the default IP address” class of questions, that’s why they suggest this forum as the primary support channel and refer to the support from your reseller.
/system logging
add topics=debug
Have tried disabling this?
All versions of RouterOS above 6.34.6 in the old line of devices from MikroTik cause an increased amount of write to flash memory.
That setting is no longer active, the router has been reset to factory defaults, but the writes keep on raising no matter what.
Netinstall it then. I expect it’s been compromised.
Will try netinstall and report. Just curious, compromised how? Do you mean hacked? Or something else?
Yes, hacked.
I don’t see how could it get hacked. There are no open ports nor forwarded ports on the wan interface. None of the admin tools, like webfig or ssh are open to the exterior. The only one using the router is me.
It was only a guess based on almost zero information.
You will only find out if it’s cured by Netinstalling it.
Most likely a partially failed update or some corruption in OS.
