Very high traffic on Firewall "Drop all traffic not from Lan" rule
I recently had issues with a firmware upgrade to my home router, a hAP ac^2 (R1). After the second attempt I discovered my DHCP reservations were allmost gone, and the next day I discovered the firewall list was empty, not even the “dummy” counter remained. This has prompted me to get my secondary router up and running, an RBG750r3 (R2). Because I had to re-create the firewall on the hAP, I was a little more focused on creating the new one, and to that end I followed the Mikrotik doc on creating an advanced firewall https://help.mikrotik.com/docs/display/ROS/Building+Advanced+Firewall. I have followed that guide to the letter, only changing the entries and lists to match my particular environment (LAN IP addresses etc.). I finally got that up and running today and had it running side-by-side with R1 which has only a basic firewall. I was monitoring the firewalls to see what the differences in traffic look like and right off the bat, one thing stood out; the new router has what I would consider a ton of traffic, (20-30 p/s) that was being caught and dropped by the 3rd rule of:
add action=accept chain=input comment=“defconf: accept ICMP after RAW” protocol=icmp
add action=accept chain=input comment=“defconf: accept established,related,untracked” connection-state=established,related,untracked
add action=drop chain=input comment=“defconf: drop all not coming from LAN” in-interface-list=!LAN
Whereas R1 only had the occasional hit (0-3 p/s intermittently).
My R1 firewall config up to that rule is:
add action=accept chain=input comment=“defconf: accept established,related”
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=input comment=“PPTP VPN Incoming” disabled=yes
dst-port=1723 log=yes log-prefix=PPTP-VPN protocol=tcp
On both routers my LAN interface list contains only the ethernet port that is connected to my LAN and the bridge interface.
Can anyone see why R2 would see so much more traffic on that rule than R1? Both are connected directly to my modem and both have an IP directly from my ISP.
Sorry for the long-windedness of the post but I’m trying to include all pertinent information. At this point I’m pretty sure my R2 firewall is sound but I’m wondering if there’s something in my R1 config thats missing these packets. I’m happy to post the entire firewall config of both routers if that helps.
Thanks for any insight anyone can provide.
Because there is tons of traffic on the WWW always hitting routers, nothing unusual.
You are simply in effect logging it now by showing what is dropped.
For a starting firewall this is ideal…
{Input Chain}
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid
add action=accept chain=input in-interface-list=LAN
add action=drop chain=input comment=“drop all else” *****
{forward chain}
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=established,related,untracked
add action=accept chain=forward comment=“allow internet traffic” in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment=“allow port forwarding” connection-nat-state=dstnat
add action=drop chain=forward comment=“drop all else”
add action=masquerade chain=srcnat comment=“defconf: masquerade” out-interface-list=WAN
Dont add any more noise to the firewall other than to ensure allowed traffic is permitted like to a shared printer between vlans for example.
Thanks for the response. I did enable logging on the R1 rule, then sat there and watched the log file scroll. There was definitely 10-20x more traffic on that rule on the R2 box. I’ve unplugged it for now, but I plan on revisiting this later in the week, if I see any different behaviour I’ll post here.
I can say that there is definitely much more to the new firewall on R2, so now I’m wondering if just the basic firewall in the Mikrotik docs or what you have posted would be enough. I’m not doing anything special with these boxes, it’s just for a home setup, but I admit I’m having fun playing with this stuff. Thanks for the advice.
I have 3 layers of firewalls in the user article, https://forum.mikrotik.com/viewtopic.php?t=180838
NOVICE → raw beginner newbie
NOVICE + MODIFIED → Beginner with some experience
APPRENTICE → Beginner with confidence/knowledge/understanding
Nothing else is really required…
PS Dont forget to read para’s 3-9.
Read this through from start to finish, very helpful. thanks!
Updated it last night so some changes.
I’m interested in the topic, but the link seems to be broken. Do you have an updated link? Thanks a lot!
The link loads, but no information is displayed there.
