I don’t anderstand why I have a very low signal with my cAP ax.
Here is my conf :
# 2023-07-05 15:24:10 by RouterOS 7.10.1
# software id = NVS0-QSJW
# model = cAPGi-5HaxD2HaxD
# serial number = <removed>
add admin-mac=48:A9:8A:C2:8C:95 auto-mac=no comment=defconf name=bridge
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ac .skip-dfs-channels=10min-cac .width=20/40/80mhz configuration.country=France .hide-ssid=no .mode=ap \
.ssid=toto2@work disabled=no security.authentication-types=wpa2-psk,wpa3-psk .encryption=""
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=10min-cac .width=20/40mhz configuration.country=France .mode=ap .ssid=toto@work \
add comment=defconf name=WAN
add comment=defconf name=LAN
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add bridge=bridge interface=ether1
/ipv6 settings
set disable-ipv6=yes
/ip dhcp-client
add interface=bridge
set allow-remote-requests=yes
/ip dns static
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system note
set show-at-login=no
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
\n :if ([system leds settings get all-leds-off] = \"never\") do={\r\
\n /system leds settings set all-leds-off=immediate \r\
\n } else={\r\
\n /system leds settings set all-leds-off=never \r\
\n }\r\
\n "
/tool mac-server
/tool mac-server mac-winbox
Edit mod: removed serial, applied code quotes
