hi everybody. this little script works perfect but only with the chain 0 when i try to enable/disable chain 1, doesnt work, i have only two chains in /ip firewall filter, remember WORKS perfect with chain 0 but dont with chain 1 simply doens nothing with chain 1
[admin@router-gelo] > /ip firewal filter pr
0 X ;;; 208
chain=input action=drop protocol=icmp dst-address=192.168.208.1
1 X ;;; 209
chain=input action=drop protocol=icmp dst-address=192.168.209.1
THIS WORKS PERFECT
:global activa208 ([/interface get [/interface find name=“ether1-aba208”] disabled]);
:log info “eth1-208 DOWN: $activa208”;
:if ($activa208) do={/ip firewall filter enable numbers=0} else={
/ip firewall filter disable numbers=0};
THIS DOESNT WORK I ONLY CHANGE THE NUMBERS=0 FOR 1
What version are you using? Does second script log “eth1-208 DOWN: $activa208” part or only disable rule is the one that does not work? What is the result if you paste it directly into terminal? Also i suggest to check script policies.
hello, as mrz suggest it works perfect, it’s the actual way i yet implemented to work, but i just want an easy and direct way, without put a comment. but why doesnt work with 1?
numbers, even if they work once, wont work forever, if you introduce any new rule and move it somewhere, all your scripts will disable/enable wrong rules, that is why you have to use find clause and get rules other way.
In API you can get permanent entry IDs and work then them, they wont change, even not after reboot (for static interfaces)
Missing : before if,
missing “get” for obtain “disabled status”
missing on get…disabled
missing (for me) where after find
= yes can be omitted as @Jotne say,
but i do not like errors, I added a section to check if “test” exist…
Must exist only one time, or “get” do errors if it not exist or if are present multiple rules with test as comment.
:if ([:len [find where comment="test"]] = 1) do={
:if ([get [find where comment="test"] disabled]) do={
enable [find where comment="test"]
} else={
disable [find where comment="test"]
