Very slow download and upload speed
I have a very slow speed on my mikrotik router.
i have about 960Kbps down and 1mbps up, wich should be around 25Mbps/25Mpbs
i have a few nat rules for portfowarding, and a few pptp profiles for a VPN to the network
could you guys take a look at my config? see if i missed something since i am big noob with RouterOS
```text
[admin@kkeuter-rt01-01] > /export hide-sensitive
# jul/21/2020 22:20:15 by RouterOS 6.43.8
# software id = I1GS-X6EM
# model = 2011UiAS
# serial number = 51F304B39629
add admin-mac=4C:5E:0C:65:25:87 arp=proxy-arp auto-mac=no comment=defconf name=bridge
add arp=proxy-arp name=bridge-vpn
set 6 vlan-mode=fallback
set 7 vlan-mode=fallback
set 8 vlan-mode=fallback
set 9 vlan-mode=fallback
set 10 vlan-mode=fallback
set 12 vlan-mode=fallback
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=10.5.1.1-10.10.255.255
add address-pool=dhcp disabled=no interface=bridge name=defconf
/metarouter
add disabled=yes name=mr1
/ppp profile
add bridge=bridge-vpn local-address=dhcp name=pptp-profile remote-address=dhcp use-encryption=yes
/system logging action
set 3 remote=10.101.1.1 src-address=10.101.1.1
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
/interface pptp-server server
set default-profile=pptp-profile enabled=yes
add address=10.1.1.1/8 comment=defconf interface=ether2 network=10.0.0.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
/ip dhcp-server lease
add address=10.101.1.1 allow-dual-stack-queue=no client-id=1:0:1a:64:7:f5:be mac-address=00:1A:64:07:F5:BE
add address=10.10.0.250 client-id=1:0:c:29:85:94:60 mac-address=00:0C:29:85:94:60 server=defconf
add address=10.2.1.1 client-id=ff:bc:9a:4a:2d:0:2:0:0:ab:11:82:e3:6c:60:a:b:d8:f4 mac-address=00:0C:29:48:74:5C server=defconf
add address=10.101.1.2 client-id=1:18:a9:5:77:38:54 mac-address=18:A9:05:77:38:54 server=defconf
add address=10.2.1.2 client-id=ff:bc:9a:4a:2d:0:2:0:0:ab:11:82:6c:e9:ae:95:2e:52:34 disabled=yes mac-address=00:0C:29:F4:98:42 server=defconf
add address=10.50.1.1 client-id=ff:9f:6e:85:24:0:2:0:0:ab:11:af:96:3a:8a:bd:61:bf:f4 mac-address=00:0C:29:F4:04:6C server=defconf
add address=10.25.1.1 client-id=ff:9f:6e:85:24:0:2:0:0:ab:11:cb:8c:9e:19:db:5d:4:17 mac-address=00:0C:29:C8:64:C7 server=defconf
add address=10.2.1.2 allow-dual-stack-queue=no mac-address=00:0C:29:64:FC:80 server=defconf
add address=10.0.0.0/8 comment=defconf gateway=10.1.1.1 netmask=8
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=10.1.1.1 name=router.lan
add action=accept chain=input dst-port=1723 protocol=tcp
add action=accept chain=input dst-port=47 protocol=tcp
add action=accept chain=input protocol=gre
add action=accept chain=forward dst-port=3389 in-interface=all-ethernet out-interface=all-ethernet port=3389 protocol=tcp src-port=3389
add action=accept chain=input comment="PPTP VPN" disabled=yes dst-port=1723 protocol=tcp
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=change-mss chain=forward disabled=yes new-mss=1400 passthrough=yes protocol=tcp tcp-flags=syn
add action=dst-nat chain=dstnat dst-port=3389 in-interface=all-ethernet protocol=tcp to-addresses=10.10.0.250 to-ports=3389
add action=dst-nat chain=dstnat dst-port=80 in-interface=all-ethernet protocol=tcp to-addresses=10.2.1.1 to-ports=80
add action=dst-nat chain=dstnat dst-port=25565 in-interface=all-ethernet protocol=tcp to-addresses=10.2.1.1 to-ports=25565
add action=dst-nat chain=dstnat dst-port=25565 in-interface=all-ethernet port="" protocol=udp to-addresses=10.2.1.1 to-ports=25565
add action=dst-nat chain=dstnat dst-port=8192 in-interface=all-ethernet protocol=tcp src-address-list="" src-port="" to-addresses=10.101.1.1 to-ports=8192
add action=dst-nat chain=dstnat dst-port=21 in-interface=all-ethernet protocol=tcp src-port="" to-addresses=10.101.1.1 to-ports=21
add action=dst-nat chain=dstnat dst-port=443 in-interface=ether1 protocol=tcp to-addresses=10.2.1.1 to-ports=443
add action=dst-nat chain=dstnat dst-port=3306 in-interface=ether1 protocol=tcp to-addresses=10.10.0.250 to-ports=3306
add action=dst-nat chain=dstnat dst-port=8080 in-interface=ether1 protocol=tcp to-addresses=10.2.1.1 to-ports=8080
add action=dst-nat chain=dstnat dst-port=902 in-interface=all-ethernet protocol=tcp to-addresses=10.101.1.1 to-ports=902
add action=dst-nat chain=dstnat dst-port=22 in-interface=all-ethernet protocol=tcp to-addresses=10.2.1.1 to-ports=22
add action=dst-nat chain=dstnat disabled=yes dst-port=23 in-interface=all-ethernet protocol=tcp to-addresses=10.101.1.1 to-ports=22
add action=dst-nat chain=dstnat dst-port=81 in-interface=all-ethernet protocol=tcp to-addresses=10.10.0.251 to-ports=81
add action=dst-nat chain=dstnat dst-port=4430 in-interface=all-ethernet protocol=tcp to-addresses=10.10.1.1 to-ports=4430
add action=dst-nat chain=dstnat dst-port=2022 in-interface=all-ethernet port="" protocol=tcp src-port="" to-addresses=10.2.1.1 to-ports=2022
add action=dst-nat chain=dstnat dst-port=8443 in-interface=all-ethernet protocol=tcp to-addresses=10.10.1.1 to-ports=8443
add action=dst-nat chain=dstnat dst-port=4430 in-interface=all-ethernet protocol=udp to-addresses=10.10.1.1 to-ports=4430
add action=dst-nat chain=dstnat disabled=yes dst-port=81 protocol=udp to-addresses=10.10.1.1 to-ports=81
add action=dst-nat chain=dstnat dst-port=903 in-interface=all-ethernet protocol=tcp to-addresses=10.101.1.1 to-ports=903
add action=dst-nat chain=dstnat dst-port=1234 in-interface=all-ethernet protocol=tcp to-addresses=10.2.1.1 to-ports=1234
add action=dst-nat chain=dstnat dst-port=25566 in-interface=all-ethernet protocol=tcp to-addresses=10.2.1.1 to-ports=25566
add action=dst-nat chain=dstnat dst-port=25567 in-interface=all-ethernet protocol=tcp to-addresses=10.2.1.1 to-ports=25567
add action=dst-nat chain=dstnat dst-port=25568 protocol=tcp to-addresses=10.2.1.1 to-ports=25568
add action=dst-nat chain=dstnat dst-port=26000 in-interface=all-ethernet protocol=tcp to-addresses=10.2.1.1 to-ports=26000
add action=dst-nat chain=dstnat dst-port=27000 in-interface=all-ethernet protocol=tcp to-addresses=10.2.1.2 to-ports=27000
add action=dst-nat chain=dstnat dst-port=8081 in-interface=all-ethernet protocol=tcp to-addresses=10.2.1.2 to-ports=8081
add action=dst-nat chain=dstnat dst-port=2023 in-interface=all-ethernet protocol=tcp to-addresses=10.2.1.2 to-ports=2023
add action=dst-nat chain=dstnat dst-port=30000 in-interface=all-ethernet protocol=tcp to-addresses=10.10.0.251 to-ports=30000
add action=dst-nat chain=dstnat dst-port=30001 in-interface=all-ethernet protocol=tcp to-addresses=10.10.0.251 to-ports=30001
add action=dst-nat chain=dstnat dst-port=26011 in-interface=ether1 protocol=tcp to-addresses=10.2.1.1 to-ports=26011
add action=dst-nat chain=dstnat dst-port=3000 protocol=tcp to-addresses=10.10.0.251 to-ports=3000
add action=dst-nat chain=dstnat dst-port=3001 protocol=tcp to-addresses=10.10.0.251 to-ports=3001
add action=dst-nat chain=dstnat dst-port=27001 in-interface=all-ethernet protocol=tcp to-addresses=10.2.1.2 to-ports=27001
add action=dst-nat chain=dstnat dst-port=54984 in-interface=all-ethernet protocol=tcp to-addresses=10.10.255.229 to-ports=54984
/lcd
set time-interval=weekly touch-screen=disabled
/ppp secret
add name=ppp1 profile=pptp-profile service=pptp
add name=ppp2 profile=pptp-profile
/routing rip interface
add send=v1-2
/system clock
set time-zone-name=Europe/Amsterdam
/system identity
set name=kkeuter-rt01-01
/system logging
add action=remote topics=info
add action=remote topics=error
add action=remote topics=warning
add action=remote topics=critical
add action=remote topics=account,async,backup,bfd,bgp,bridge,dhcp,ddns,e-mail,dns,firewall,interface,kvm,route,write
/tool mac-server
/tool mac-server mac-winbox
Should probably be
add address=10.1.1.1/8 comment=defconf interface**=bridge** network=10.0.0.0
Hi, thank you for your anwser.
i changed the setting, and reboot the router, but sadly no difrence.
6.43.8…why?
What is the CPU consumption while testing?
Is 6.43 an old version? i dont know very much about RouterOS
The CPU usage is about 10%
It is indedeed an older version:
https://mikrotik.com/download/archive
You might want to give 6.47.1 (latest stable release) or 6.45.9 (latest long-term release) a try.
i have downloaded and updated the routeros version, but this still made no difrence, thanks for the tip to upgrade my routeros!
and thanks for your time
Fasttrack is probably not working because firewall filter rule order is wrong:
These two should be in the reverse order so that fasttrack rule actually gets something to accept.
