Very slow download speed - Please help!
Hi, I am experiencing extremely slow upload speeds (3-4 MB per sec, to the 800-1GB I should be having) and I wonder if it’s because my router has a poor config.
I have the default configuration and any change made it was randomly trying to solve this issue. I’m very far from an expert so I most likely wont be able to answer technical questions about it, I’m just a normal user at the moment.
I was hoping that some of the more experienced people could help me solve my issue, or provide some insight. I’d rather not have to put back the default router my IPS offered to me as it was giving me other issues.
I’ve searched how to print the config and this has been the result. Thanks in advance :slight_smile:
Config:
# 2025-02-04 14:54:21 by RouterOS 7.17.1
# software id = GFWJ-36SH
# model = C52iG-5HaxD2HaxD
# serial number = <edited>
add admin-mac=48:A9:8A:D6:D0:F4 auto-mac=no comment=defconf name=bridge \
    port-cost-mode=short
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
    configuration.country=Spain .mode=ap .ssid=MikroTik-D6D0F9-5G disabled=no \
    security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
    configuration.country=Spain .mode=ap .ssid=MikroTik-D6D0F9 disabled=no \
/interface vlan
add interface=ether1 name=vlan20-digi vlan-id=20
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan20-digi name=\
    digi-internet use-peer-dns=yes user=387715640@digi
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/ip smb users
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=wifi1 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=wifi2 internal-path-cost=10 \
    path-cost=10
set udp-timeout=10s
add interface=digi-internet list=WAN
/interface ovpn-server server
add mac-address=FE:D5:F5:B1:BC:A7 name=ovpn-server1
    192.168.88.0
/ip dhcp-client
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip firewall mangle
add action=change-mss chain=forward comment=\
    "Clamp MSS to PMTU for Outgoing packets" new-mss=clamp-to-pmtu protocol=\
    tcp tcp-flags=syn
add action=change-mss chain=output new-mss=clamp-to-pmtu protocol=tcp \
    tcp-flags=syn
    tcp tcp-flags=syn
    tcp-flags=syn
/ip hotspot profile
/ip ipsec profile
/ip smb shares
set [ find default=yes ] directory=/pub
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
/tool netwatch
add disabled=yes down-script="" host=8.8.8.8 http-codes="" interval=10s \
    test-script="" type=simple up-script=""
router-config.rsc (7.84 KB)
Mangle rules and fasttrack don’t cooperate. So disable the fasttrack rule in firewall filter.
I think I’ve done as you say and now both speeds (download and upload) are slower (500MBps download and 1MBps upload), or at least there is no change.
This is the new config:
# 2025-02-04 15:48:07 by RouterOS 7.17.1
# serial number = HEH08KF5KKZ
/interface wifi
/interface vlan
/ip smb users
    path-cost=10
    path-cost=10
    path-cost=10
    path-cost=10
    path-cost=10
    path-cost=10
set udp-timeout=10s
    192.168.88.0
/ip dhcp-client
    192.168.88.1
/ip dns static
    invalid
    connection-state=established,related disabled=yes hw-offload=yes
/ip firewall mangle
    tcp tcp-flags=syn
    tcp-flags=syn
    tcp tcp-flags=syn
    tcp-flags=syn
/ip hotspot profile
/ip ipsec profile
/ip smb shares
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/system note
/tool mac-server
/tool netwatch
router-config-2.rsc (7.86 KB)
Disabling fasttrack can have “delayed effect”, the existing connectiins are still fasttracked. It’s best to reboot router to get things reset to (new) settings.
BTW, your router’s test results indicate routing speed at around 900Mbps. But depending on actual configuration it can be much lower. Disabling fasttrack is one of those configs which does affect performance very much …
I rebooted the router with no success even after a while. My ISP contract says my optic fiber should be symmetric, so I expect upload speeds much higher than 3/1000, even if there is a loss like the download speed.
Thanks for the advice in any case :slight_smile:
Maybe best to start from scratch with default config and test.
Then make your changes (small steps) and test in between.
It should be obvious where the degradation happens. The last change is most likely your first place to look for then.
  1. Remove this or disable it, you already are using pppoe as your ISP client interface.
    /ip dhcp-client
2.What are these for??? they are not attached to any interface??? If you dont know remove’…
/ip firewall mangle
“Clamp MSS to PMTU for Outgoing packets” new-mss=clamp-to-pmtu protocol=
tcp tcp-flags=syn
tcp-flags=syn
tcp tcp-flags=syn
tcp-flags=syn
  1. With these changes report back on behaviour
I reset the config as advised and did it again until I got back a connection. Still having the same results in different speed tests.
Current config:
# 1970-01-02 00:36:11 by RouterOS 7.17.1
/interface wifi
    configuration.mode=ap .ssid=MikroTik-D6D0F8 disabled=no \
    security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
/interface vlan
add interface=ether1 name=vlan1-Digi vlan-id=20
add add-default-route=yes disabled=no interface=vlan1-Digi name=\
    pppoe-out1-Digi use-peer-dns=yes user=387715640@digi
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add interface=pppoe-out1-Digi list=WAN
    192.168.88.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
    192.168.88.1
/ip dns static
    invalid
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/system note
/tool mac-server
Reply:
/ip firewall mangle
tcp tcp-flags=syn
tcp-flags=syn
tcp tcp-flags=syn
tcp-flags=syn
Those are from another post where someone said it solved their problem. But given I don’t know anything I just put those in the terminal, I guess I really didn’t do what I was supposed to.
router-config-3.rsc (6.68 KB)
IMO configuration from your latest post doesn’t explain the extremely low throughput in download direction.
Can you check the stats on ether1 port? Does it show any errors?
I’m not sure how to check those, as I said I’m very very novel atm.
I attached a screenshot with the status of ether1 if that helps.
It would be under Tx stats and Rx stats …
I attach what appears in those sections + overall stats.
