Very Slow output for traffic passing through CHR
UPDATE IN BELOW POST - No longer think this is a GRE Tunnel issue
Basic Setup:
CHR P10 licensed & activated, hosted on Vultr cloud hosting provider running 7.2 Stable, 1000Mbps/1000Mbps
CCR hardware running 6.48.6 Long Term, 1000Mbps / 45Mbps
Topology:
Office Workstation (Private: 10.0.0.5/27)
V
CCR (Public: 1.1.1.1/29, Private: 10.0.0.1/27, Tunnel: 172.16.1.1/30)
V
TUNNEL (GRE, EOIP, or IPIP with IPsec)
V
CHR (DHCP assigned fake-static Public: 2.2.2.2/23, Private: 10.1.0.1/27, Tunnel: 172.16.1.2/30)
V
Virtual Server (Private: 10.1.0.5)
I initially created a GRE tunnel with IPsec Secret between the two endpoints. The Tunnel connects, and IPsec Active Peers show up as expected. After adding Routes, I can pass traffic as expected. Everything looked good until I attempted to pass actual workloads through the tunnel… and discovered they are extremely slow, less than 1Mbps and often in the Kbps range.
I disabled IPsec Secret and tried just a plain tunnel, same thing.
I tried the same configuration, but used EOIP and IPIP instead. Same thing with both.
If I do a BTest between both mikrotiks, I can achieve reasonable throughput (300-700Mbps+ down, depending if IPsec is enabled or not).
If I bypass the CHR and talk directly to a public IP on the cloud Virtual Server, I can achieve maximum throughput as well, which would indicate it’s not the virtual server, perhaps.
The problem only occurs when passing traffic through the CHR either direction.
Sniffing the connection, I see a lot of retransmissions and duplicate packets - unsure if that is the problem or standard for a tunnel like this. Seems suspicious though.
I’ve attached cleaned/trimmed exports from each side. I tried to remove things that were obviously unrelated, such as our “road warrior” IKEv2 configs. If something doesn’t make sense, let me know and I’ll check the config.
CHR:
# apr/21/2022 17:25:19 by RouterOS 7.2
# software id =
set [ find default-name=ether1 ] disable-running-check=no
set [ find default-name=ether2 ] comment=\
    "MTU 1450 per Vultr VPC Documentation" disable-running-check=no mtu=1450
/interface gre
add allow-fast-path=no mtu=1426 name=gre-tunnel2 remote-address=1.1.1.1
/disk
set sata1 disabled=no
add name=WAN
add name=LAN
/ip ipsec profile
set [ find default=yes ] dh-group=modp1024 enc-algorithm=aes-128
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc lifetime=8h pfs-group=\
    modp4096
add interface=ether1 list=WAN
add interface=ether2 list=LAN
add interface=gre-tunnel2 list=LAN
add list=LAN
/interface ovpn-server server
set auth=sha1,md5
add address=10.1.0.1/27 interface=ether2 network=10.1.0.0
add address=172.16.1.2/30 interface=gre-tunnel2 network=172.16.1.0
/ip dhcp-client
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=10.1.0.4 name=db.example.net
add address=10.1.0.5 name=cloud.example.net
/ip firewall address-list
add address=1.1.1.1/29 list=office
add address=10.0.0.1/27 list=office
add address=172.16.1.0/30 list=gre_tunnel
add action=accept chain=input comment="Accept all GRE Tunnel Traffic" \
    protocol=gre src-address-list=office
    dst-address-list=gre_tunnel protocol=gre
    "VPN IPSec Encapsulating Security Payload (ESP)" protocol=ipsec-esp
    "VPN IPSec Encapsulating Security Payload (AH)" protocol=ipsec-ah
add action=accept chain=input comment="Allow ICMP" protocol=icmp
    "Allow LAN to access Services (DNS, etc)" in-interface-list=LAN
add action=accept chain=input comment="Allow Established & Related" \
add action=accept chain=input comment="Allow All Traffic from Office" \
    in-interface-list=WAN src-address-list=office
add action=drop chain=input comment="Drop Everything Else" log=yes \
    log-prefix=DROP
add action=accept chain=forward comment="Allow All Traffic from Office" \
    out-interface-list=LAN src-address-list=office
add action=accept chain=forward comment="Allow All Traffic to Office" \
    dst-address-list=office out-interface-list=WAN
add action=accept chain=forward comment="Allow Established & Related" \
add action=accept chain=forward comment="Allow LAN to Talk to Each Other" \
    connection-state=new in-interface-list=LAN
add action=drop chain=forward comment="Drop Everything Else" log=yes \
    log-prefix=DROP
add action=masquerade chain=srcnat comment="Default Masquerade" \
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip ipsec policy
set 0 disabled=yes
add disabled=no distance=1 dst-address=10.0.0.1/27 gateway=gre-tunnel2 \
    pref-src=0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=America/Los_Angeles
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.us.pool.ntp.org
add address=1.us.pool.ntp.org
add address=2.us.pool.ntp.org
/tool sniffer
set file-limit=5000KiB file-name=CAPTURE2.cap memory-limit=2000KiB
CCR:
# apr/21/2022 17:26:04 by RouterOS 6.48.6
# software id =
# model = CCR1009-8G-1S-1S+
# serial number =
set [ find default-name=ether1 ] l2mtu=1588 speed=100Mbps
set [ find default-name=ether2 ] disabled=yes l2mtu=1588 speed=100Mbps
set [ find default-name=ether3 ] disabled=yes l2mtu=1588 speed=100Mbps
set [ find default-name=ether4 ] disabled=yes l2mtu=1588 speed=100Mbps
set [ find default-name=ether5 ] disabled=yes l2mtu=1590 speed=100Mbps
set [ find default-name=ether6 ] disabled=yes l2mtu=1590 speed=100Mbps
set [ find default-name=ether7 ] disabled=yes l2mtu=1590 speed=100Mbps
set [ find default-name=ether8 ] l2mtu=1590 speed=100Mbps
set [ find default-name=sfp-sfpplus1 ] advertise=\
    10M-full,100M-full,1000M-full l2mtu=1590
set [ find default-name=sfp1 ] advertise=10M-full,100M-full,1000M-full \
/interface gre
add allow-fast-path=no mtu=1426 name=gre-tunnel2 remote-address=\
    2.2.2.2
add name=LAN
set [ find default=yes ] supplicant-identity=CCR1
/ip ipsec profile
/ip ipsec proposal
    modp4096
add name=dhcp_pool1 ranges=10.0.0.2-10.0.0.30
add address-pool=dhcp_pool1 authoritative=after-2sec-delay interface=sfp-sfpplus1 \
    name=dhcp1
add interface=sfp-sfpplus1 list=LAN
add address=1.1.1.1/29 interface=ether1 network=1.1.1.0
add address=10.0.0.1/27 interface=sfp-sfpplus1 network=10.0.0.0
add address=172.16.1.1/30 interface=gre-tunnel2 network=172.16.1.0
add address=10.0.0.0/24 dns-server=10.0.0.1 gateway=\
    10.0.0.1
add address=10.0.0.0/24 comment="Our LAN Subnet" list=LAN
add address=2.2.2.2 list=CLOUD-SERVERS
add address=10.1.0.0/27 list=CLOUD-SERVERS
add address=172.16.1.0/30 list=GRE-TUNNEL
    protocol=gre src-address-list=CLOUD-SERVERS
    dst-address-list=GRE-TUNNEL protocol=gre
add action=accept chain=input comment="Established & Related Connections" \
add action=accept chain=input comment="Allow External Ping" protocol=icmp
add action=drop chain=input comment="Drop Invalid Connections" \
    connection-state=invalid log=yes log-prefix=INVALID
    "VPN IPSec Encapsulating Security Payload (ESP)" log-prefix=IPSEC- \
    protocol=ipsec-esp
    "VPN IPSec Encapsulating Security Payload (AH)" log-prefix=IPSEC- \
    protocol=ipsec-ah
add action=accept chain=input comment="VPN IPSec Internet Key Exchange (IKE)" \
    dst-port=500 log-prefix=IPSEC- protocol=udp
add action=accept chain=input comment="VPN IPSec NAT Traversal (NAT-T)" \
    dst-port=4500 log-prefix=IPSEC- protocol=udp
add action=accept chain=input comment="Allow LAN => Router" src-address-list=\
    LAN
    log-prefix=DROP
add action=accept chain=forward comment="Established & Related Connections" \
add action=drop chain=forward comment="Drop Invalid Connections" \
add action=masquerade chain=srcnat comment=\
    "Default NAT Masquerade: LAN --> WAN" out-interface=ether1
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/ip ipsec policy
set 0 disabled=yes
add distance=1 gateway=1.1.1.0
add distance=1 dst-address=10.1.0.0/27 gateway=gre-tunnel2
I think I’ve narrowed the problem down to traffic going from any of the cloud servers through the CHR. So output from the CHR’s perspective.
A MTR in both directions shows zero packet loss:
Cloud Server to Cloud Server throughput is great, measured with iperf:
And Office upload to Cloud Server is fine, however… Cloud Server upload to Office is terrible:
I tried another Cloud Server in the Virtual Private Network (VPC in Vultr terms) and got the same results:
I even tried running Speedtest.net from the Cloud Server and got similar results:
A BTest from the CHR to the CCR looks reasonable for being a IPsec inside a tunnel, which means it’s traffic passing through the CHR that is the issue, not traffic originating from the CHR:
What is going on here? I can’t seem to think of any configs in the CHR that would throttle things like this. The servers are all Rocky Linux 8.x, with a mostly vanilla setup. If it was a networking issue on the servers I would expect to see the same problems with all traffic, not just traffic going outbound through the CHR.
This makes me think this is not a GRE tunnel issue… I’m not sure what to make of this.
Hmm… MTU or fragmentation issue?
Just start count the overhead backwards from the MTU used by your ISP
Thanks. I had initially suspected a possible MTU issue.
According to Vultr, all interfaces on the VPC network must bet set to 1450 MTU.
https://www.vultr.com/docs/how-to-create-a-vultr-virtual-private-cloud-vpc/
When initially creating the VM, if you attach it to a VPC network is auto-sets the MTU on the correct interface.
So this means,
CHR:
ether1 WAN - MTU 1500
ether2 LAN - MTU 1450
GRE-Tunnel - MTU 1426 (guessed here, matches CCR side as well)
VM:
ether1 DISABLED
For traffic that is VM → CHR → Public, it should go MTU1450 → ( MTU1450 → BUFFER → MTU1500 ) → Public, where everything between the parentheses are inside the CHR.
From one of the cloud VM’s (interface MTU 1450), doing a
ping 4.2.2.2 -M do -s 1422
returns fine, but using a packet size of 1423 errors out and needs to fragment. This leaves overhead of about 28 bytes for a VM → Public packet.
I also tried re-enabling one of the cloud VM’s public interfaces (not behind the CHR, attached directly to the public) and a speedtest shows just shy of 5Gbps in both directions:
So it seems to entirely be related to traffic going through the CHR. VM to VM traffic is good (about 2Gbps). VM to public traffic is good (about 5Gbps). VM traffic through CHR is bad (less than 1Mbps).
Not sure where this leaves me…
I ran into the same issue but with slow upload speeds from my VPC nodes to the outside via mikrotik.
I had reached out their tech support, we ran some tests and everything had point out to the router.
I am sure it’s not 100% mikrotik issue, but it seems to me that it’s a combination of the way how VPC is organized.
Had anyone had success on this problem?
Thanks.
Did you ever resolve this?
I’m having similar issues and looking for answers.
I’m having a similar problem in a Vultr environment. The virtual Mikrotik CHR (running 7.6) can upload/download over 500mb/s on the WAN port. The cloud computers connected to it on the virtual LAN can download over 500mb/s, but only upload 7-10mb/s. And even uploading to the Mikrotik directly from the cloud computers is constrained by this speed.
I will note that the problem was initially much worse, with uploads in the 250kb/s range. What helped was reinstalling the cloud Mikrotik CHR on an Intel platform vs. AMD. But the upload of 7-10mb/s is still awful. Tried many MTU settings with no change. Currently have 1450 set on the Mikrotik LAN, as recommended. On the cloud computers (running Windows) I’ve got the MTU set to 1422 which is optimal to avoid fragmentation.
I have another Vultr account with a nearly identical setup and on that one the uploads work fine. Anyone else run into this?
Same same, just found this post, after umpteen MTU adjustments and iperf tests between Windows and Linux hosts over the Vultr VPC I can only get 300-600Mbps - Mbps!
(tried lots of mtu values from 1300 up to 1450)
Like poster above said if enabling NIC connecting directly to internet get 4Gbps from Speedtest.net.
Going to give up on Vultr I think.
I’m having same issue with vultr +mtik +server 2022. Upload speed through mtik on server 2022 is 2mbit/s max. Otherwise everything is fine.
Anybody figure this out?
Same issue here. Vultr support is of no help. Anybody found a solution?
I wasted time today with this until I found this forum.
CHR with a P1 license on Vultr. Connects internally to a Debian VM which has it’s public interface disabled - all traffic is routed through the CHR. The VM downloads at >800Mbit, that’s fine. Uploads are in the 1Mbit range and Wireshark shows a lot of retransmissions. The posts above don’t give me much hope. VPC2 didn’t work well (I can’t recall why, similar issues?) so I dropped back to VPC. MTU’s on all interfaces are fine 1450 for CHR eth2 and the Debian VM 2nd interface. Public interfaces are 1500. Mucking with MSS mangles and dropping MTU doesn’t help. This is disappointing!
Testing with iPerf3 from a Debian VM inside communicating with an external server via the CHR with a P1 license (using masquerading):
TCP: WAN->VPC Speeds are fine.
TCP: VPC->WAN Speeds are slow and erroneous connections.
UDP: WAN->VPC Speeds are fine.
UDP: VPC->WAN Speeds are fine.
I initially noticed the problem when I set up a Rustdesk server on the Debian VM and relay performance was abysmal, the opposite of what I expected. I am wondering if there is a problem with connection tracking for TCP in this particular arrangement.
I tried with VPC2 but I rediscovered the reason I don’t use it is that in my case only IP traffic for the same VPC2 subnet seems to work, anything outside of that does not - eg trying to ping 1.1.1.1 from the VM though the CHR shows the traffic doesn’t even make it to the CHR’s VPC2 interface. Ping traffic or DNS lookups to the CHR work fine. There is some ARP weirdness going on as on the VM the ARP entry for the CHR is a completely different MAC address to what’s assigned on the CHR’s interface. Vultr support wasn’t helpful.
I seem to have solved this problem by running a simple GRE tunnel through the VPC interfaces on the CHR and Debian VM. iperf3 now runs at expected speeds in both directions with UDP and TCP.
In this and the cases above the corruption of TCP traffic between a CHR and a VM using Vultr’s VPC service is not explained but can be worked around with a tunnel as I did with GRE.
