Very slow upload speed - Please help!
Hi, I am experiencing extremely slow upload speeds (3-4 MB per sec, to the 800-1GB I should be having) and I wonder if it’s because my router has a poor config.
I have the default configuration and any change made it was randomly trying to solve this issue. I’m very far from an expert so I most likely wont be able to answer technical questions about it, I’m just a normal user at the moment.
I was hoping that some of the more experienced people could help me solve my issue, or provide some insight. I’d rather not have to put back the default router my ISP offered to me as it was giving me other issues.
I’ve searched how to print the config and this has been the result. Thanks in advance :slight_smile:
Config:
# 2025-02-05 15:06:04 by RouterOS 7.17.1
# software id = GFWJ-36SH
# model = C52iG-5HaxD2HaxD
# serial number = HEH08KF5KKZ
add admin-mac=48:A9:8A:D6:D0:F4 auto-mac=no comment=defconf name=bridge
/interface vlan
add interface=ether1 name=vlan1-Digi vlan-id=20
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan1-Digi name=\
    pppoe-out1-Digi use-peer-dns=yes user=387715640@digi
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi channel
add disabled=no frequency=2412,2432,2472 name=ch-2ghz width=20mhz
add disabled=no frequency=5180,5260,5500 name=ch-5ghz width=20/40/80mhz
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk comment=LifterEmpowerDeviatorShell \
    disabled=no name=common-auth wps=disable
/interface wifi configuration
add country=Spain disabled=no name=common-conf security=common-auth ssid=\
    MikroTik-Alberto
/interface wifi
set [ find default-name=wifi1 ] channel=ch-5ghz configuration=common-conf \
    configuration.mode=ap .ssid=MikroTik-Alberto-5G disabled=no
set [ find default-name=wifi2 ] channel=ch-2ghz configuration=common-conf \
    configuration.mode=ap .ssid=MikroTik-Alberto-2G disabled=no
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add interface=pppoe-out1-Digi list=WAN
    192.168.88.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip firewall mangle
add action=change-mss chain=forward comment=\
    "Clamp MSS to PMTU for Outgoing packets" disabled=yes new-mss=\
    clamp-to-pmtu protocol=tcp tcp-flags=syn
add action=change-mss chain=output disabled=yes new-mss=clamp-to-pmtu \
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Madrid
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
router-config.rsc (7.31 KB)
First just to be clear. 3-4MB MB ps = 25-33 Mpbs.
Second: try disabling your mangle rules to see if that makes a difference.
Other than that can only suspect a cable issue somewhere.
Which mangle rules?
I mean, the two that are both disabled=yes? :open_mouth:
:laughing:
The mangle rules are indeed disabled.
My cable is a RJ45, didn’t give me any issues in the past. But I understand the problem might not be in the configuration of the router then. I’ll try to contact my ISP again and see if there is anything on their end they can double check, or send me a different router on their side to test the speed one more time.
Thanks in any case :slight_smile:
Generally speaking, in a simple configuration like yours, a (wrong) mangle rule is the only thing that may slow down something, other issues in configuration tend to be on/off, packets either go/through or they don’t, interface Is either natted or It Is not, routes are either active or they are not.
From what I understand your configuration seems fine, if It used to work and now It doesn’t anymore It may also be an issue with the hardware, but It would be strange, as that Is also in most cases on/off.
The probability that your ISP Is (accidentally) throttling your upload connection is (IMHO) low, but It Is definitely possible.
I think the problem is solved!
A technician came today to check with a router issued by the company and he was getting normal speeds. Then I asked him if he could test with the MikroTik, and he also got normal speeds. Ofc I was baffled, then I asked one more time if he could test using my cable, in case my RJ45 was fucked, but then again he got normal speeds.
So, puzzled, I spent over 2 hours checking windows configurations and posts using different wording to get different results. And eventually I came up with a post in a Windows forum that was complaining about an issue very similar to mine and how they solved it.
Apparently, my PC came with a preinstalled Killer Intelligence Center app, which controls the Ethernet controller, or that’s what I understood. This app has a mode called “Prioritization Engine” or something similar. This must’ve been working ok at the beginning but at some point it must’ve fucked up, because as soon as I turned it off (per the post instructions) it worked like a charm!
So I’m getting again 850-900 Mbps upload speeds.
Thanks to the people that tried to help. I will post this answer with my solution in case someone happens to stumble with a similar case and, like me, doesn’t know if something in his configuration is off.
Likely you have to thank Windows Update for the issue:
https://www.dell.com/community/en/conversations/xps-desktops/killer-prioritization-engine-caused-issues-for-some-web-sites/647fa2b2f4ccf8a8de84f215
Reminds me of this post…
http://forum.mikrotik.com/t/simple-ap-bridge-setup/126375/30
