Hi all -
We recently switched to a new internet connection (fiber 20/20) and we have problems with our upload speed if connected via our RB750G.
Connected directly (notebook), i get the full 20/20 with the speedtest of our provider
Connected via RB750G, i only get 20/2 to 20/3 with the same speedtest
I’m the only one producing traffic - this is a result of multiple speedtests so it shows an overall image.
WinBox 6.12 on RB750G
No queues are configured
No flow control configured
No traffic shaping asfaik: where should i take a look?
anyone a hint what could be wrong or where to look?
many thanks in advance!
jarda
July 16, 2014, 4:57am
3
/export compact is not needed as /export command automatically produces compact output on these versions.
jarda
July 16, 2014, 3:41pm
5
I know you know. But jjarolim maybe not.
I not want jjarolim for his own idea put “/export verbose”.
For not misunderstand and be clear, “/export compact” is better…
Were you able to resolve your issue? I have having the same problem with nearly all Mikrotiks across fiber circuits. We have checked the MTUs, port speed duplex/negotiation settings/etc. On average I get about half of the available upload speed - download speed is usually okay (close to full speed). If I connect a notebook directly, I receive no speed issue. As soon as I add Mikrotik, I have the same issue that you are experiencing. I have even used a Cloud Core Router for testing.
Soren
April 7, 2018, 9:49am
8
I am sorry to rebounce this post again but I have the same problem.
Our ISP is delivering 300 / 300 MBit but the real output is current 300 MBit download / 4 MBit upload.
The net is shared between other companies but doing the test around the Mikrotik router shows full bandwith of 300 / 300 MBit. So I assume the problem must be in our RB750GR2. Could someone please take a look at my current router configuration and see if they can spot an issue within it?
Thanks in advance.
# apr/06/2018 16:52:21 by RouterOS 6.41.3
# software id = 79NE-WWU7
# model = RouterBOARD 750G r2
# serial number = 64FB0618613C
add admin-mac=AA:AA:AA:AA:AA:AA arp=proxy-arp auto-mac=no comment=\
"created from master port" name=bridge1 protocol-mode=none
set [ find default-name=ether2 ] arp=proxy-arp name=ether2-master speed=1Gbps
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
/ip hotspot profile
add name=sstp-dhcp ranges=10.0.2.1-10.0.2.10
add address-pool=default-dhcp authoritative=after-2sec-delay interface=bridge1 \
name=defconf
/ppp profile
add local-address=sstp-dhcp name=sstp-profile remote-address=sstp-dhcp \
use-encryption=required
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
add bridge=bridge1 interface=ether2-master
set discover-interface-list=discover
add interface=bridge1 list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=bridge1 list=mactel
add interface=bridge1 list=mac-winbox
/interface sstp-server server
set authentication=mschap2 certificate=ca.crt_0 default-profile=sstp-profile \
enabled=yes force-aes=yes pfs=yes
add address=192.168.88.1/24 comment=defconf disabled=yes interface=bridge1 \
network=192.168.88.0
add address=10.0.0.1/24 interface=bridge1 network=10.0.0.0
add address=xxx.xxx.xxx.43/29 interface=ether1 network=xxx.xxx.xxx.40
add address=xxx.xxx.xxx.44/29 interface=ether1 network=xxx.xxx.xxx.40
add address=172.16.1.1 interface=ether3 network=255.255.255.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.88.1 name=router
add action=accept chain=input comment="defconf: accept established,related" \
add action=accept chain=input dst-address=xxx.xxx.xxx.44 dst-port=443 protocol=\
tcp
add action=drop chain=input comment="defconf: drop all from WAN" in-interface=\
ether1
add action=accept chain=forward comment="defconf: accept established,related" \
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
connection-state=new in-interface=ether1
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=\
ether1
add action=dst-nat chain=dstnat comment=\
"Public IP xxx.xxx.xxx.43 HTTPS" dst-address=xxx.xxx.xxx.43 \
dst-port=443 protocol=tcp to-addresses=10.0.0.253 to-ports=443
add action=masquerade chain=srcnat dst-address=10.0.0.253 dst-port=443 \
out-interface=bridge1 protocol=tcp src-address=10.0.0.0/24
"Public IP xxx.xxx.xxx.43 HTTP" dst-address=xxx.xxx.xxx.43 \
dst-port=80 protocol=tcp to-addresses=10.0.0.253 to-ports=80
add action=masquerade chain=srcnat dst-address=10.0.0.253 dst-port=80 \
"Public IP xxx.xxx.xxx.43 HTTP 20080" dst-address=\
xxx.xxx.xxx.43 dst-port=20080 protocol=tcp to-addresses=10.0.0.206 \
to-ports=20080
add action=masquerade chain=srcnat dst-address=10.0.0.206 dst-port=20080 \
add distance=1 gateway=xxx.xxx.xxx.41
/ip service
set ftp disabled=yes
set www port=20081
set ssh disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub
/ppp secret
add name=John password=xyz1 profile=sstp-profile service=sstp
add name=Peter password=xyz2 profile=sstp-profile service=sstp
add name=Ellis password=xyz3 profile=sstp-profile service=sstp
add name=Porter password=xyz4 profile=sstp-profile service=sstp
add name=Tora password=xyz5 profile=sstp-profile service=sstp
/system clock
set time-zone-name=Europe/Copenhagen
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
Soren
April 8, 2018, 9:09pm
9
Just to be clear:
Like the original poster stated, the following is also true for me:
No traffic shaping
try to dissable all your firewall rules. Then just add a src-nat masqurade and test bandwith. I think this might have somethig to do with your packetflow. Best is to just have the setup:
Wan ip
Lan ip
nat
No other settings at all. Then try. If this is ok. try to add your setup on parameter at the tiine . and see what makes speed go down. (firewall)
Soren
April 9, 2018, 7:55am
11
Thanks for the advice, I will try that in evening.
