On first, sorry for my english.
I want to ask you for your help in solving a very serious and strange problem.
I have 1100AHx2 connected to my private network with several public Access Points.
On routerboard I have active HotSpot server with users db and captive portal through which users must log-in in order to gain access to the Internet.
Everything working perfectly, but, from beginning of this year (maybe, after upgrading router os) I register unexplained behavior with this hotspot.
Some users when connect to the access point does not appear captive portal from MikroTik.
They have totally denial of service with Mikrotik (192.168.0.1/23).
They can get an IP address from the DHCP pool on this Mikrotik, but then they can’t ping router and can’t show HotSpot Captive Portal. And of course they do not have access to the Internet.
BUT some other users on the same Access Point (same time) but different mobile phones, or tablets or notebooks - they have. After approximatelly 1-2 days is layout of working and non-working users different.
BUT, when I disable HotSpot (in IP->HotSpot->Servers) and enable it again - all users begin working (for a while, for hours or on few days, it’s different).
I’m totally desperate.
Here is log from active HotSpot:
Feb 3 15:58:42 MikroTik DanielaH (192.168.0.86): trying to log in by cookie
Feb 3 15:58:42 MikroTik DanielaH (192.168.0.86): using profile <ziaci>
Feb 3 15:58:42 MikroTik DanielaH (192.168.0.86): adding ip->user binding
Feb 3 15:58:42 MikroTik DanielaH (192.168.0.86): logged in
Feb 3 15:58:42 MikroTik DanielaH (2C:8A:72:8F:6B:C2): remove cookie: user logged in
Feb 3 15:58:42 MikroTik DanielaH (2C:8A:72:8F:6B:C2): add cookie: user logged in
Feb 3 15:58:50 MikroTik hotspot1: new host detected 24:0A:64:16:EB:89/192.168.0.76 by UDP :50762 -> 192.168.0.1:53
Feb 3 15:58:50 MikroTik hotspot1: host 24:0A:64:16:EB:89/192.168.0.76 is blocked
Feb 3 15:59:02 MikroTik hotspot1: new host detected 8C:3A:E3:35:45:A6/192.168.0.72 by UDP :58736 -> 192.168.0.1:53
Feb 3 15:59:02 MikroTik hotspot1: host 8C:3A:E3:35:45:A6/192.168.0.72 is blocked
Feb 3 15:59:20 MikroTik hotspot1: new host detected 74:04:2B:2C:4A:F1/192.168.0.39 by UDP :54048 -> 192.168.0.1:53
Feb 3 15:59:20 MikroTik hotspot1: host 74:04:2B:2C:4A:F1/192.168.0.39 is blocked
Feb 3 15:59:30 MikroTik hotspot1: new host detected E0:2C:B2:09:A7:82/192.168.0.56 by UDP :12989 -> 192.168.0.1:53
Feb 3 15:59:30 MikroTik hotspot1: host E0:2C:B2:09:A7:82/192.168.0.56 is blocked
Feb 3 15:59:52 MikroTik hotspot1: new host detected 24:0A:64:16:EB:89/192.168.0.76 by UDP :51767 -> 192.168.0.1:53
Feb 3 15:59:52 MikroTik hotspot1: host 24:0A:64:16:EB:89/192.168.0.76 is blocked
Feb 3 16:00:05 MikroTik hotspot1: new host detected 8C:3A:E3:35:45:A6/192.168.0.72 by UDP :20212 -> 192.168.0.1:53
Feb 3 16:00:05 MikroTik hotspot1: host 8C:3A:E3:35:45:A6/192.168.0.72 is blocked
Feb 3 16:00:20 MikroTik hotspot1: new host detected 74:04:2B:2C:4A:F1/192.168.0.39 by UDP :55918 -> 192.168.0.1:53
Feb 3 16:00:20 MikroTik hotspot1: host 74:04:2B:2C:4A:F1/192.168.0.39 is blocked
Feb 3 16:00:31 MikroTik hotspot1: new host detected E0:2C:B2:09:A7:82/192.168.0.56 by UDP :24008 -> 192.168.0.1:53
Feb 3 16:00:31 MikroTik hotspot1: host E0:2C:B2:09:A7:82/192.168.0.56 is blocked
Feb 3 16:00:56 MikroTik hotspot1: new host detected 24:0A:64:16:EB:89/192.168.0.76 by UDP :52291 -> 192.168.0.1:53
Feb 3 16:00:56 MikroTik hotspot1: host 24:0A:64:16:EB:89/192.168.0.76 is blocked
Feb 3 16:01:07 MikroTik hotspot1: new host detected 8C:3A:E3:35:45:A6/192.168.0.72 by UDP :16441 -> 192.168.0.1:53
Feb 3 16:01:07 MikroTik hotspot1: host 8C:3A:E3:35:45:A6/192.168.0.72 is blocked
Feb 3 16:01:23 MikroTik hotspot1: new host detected 74:04:2B:2C:4A:F1/192.168.0.39 by UDP :29483 -> 192.168.0.1:53
Feb 3 16:01:23 MikroTik hotspot1: host 74:04:2B:2C:4A:F1/192.168.0.39 is blocked
Feb 3 16:01:31 MikroTik hotspot1: new host detected E0:2C:B2:09:A7:82/192.168.0.56 by UDP :36269 -> 8.8.8.8:53
Feb 3 16:01:31 MikroTik hotspot1: host E0:2C:B2:09:A7:82/192.168.0.56 is blocked
Feb 3 16:01:58 MikroTik hotspot1: new host detected 24:0A:64:16:EB:89/192.168.0.76 by UDP :59117 -> 192.168.0.1:53
Feb 3 16:01:58 MikroTik hotspot1: host 24:0A:64:16:EB:89/192.168.0.76 is blocked
Feb 3 16:02:11 MikroTik hotspot1: new host detected 8C:3A:E3:35:45:A6/192.168.0.72 by UDP :42875 -> 192.168.0.1:53
Feb 3 16:02:11 MikroTik hotspot1: host 8C:3A:E3:35:45:A6/192.168.0.72 is blocked
Feb 3 16:02:23 MikroTik hotspot1: new host detected 74:04:2B:2C:4A:F1/192.168.0.39 by UDP :8101 -> 192.168.0.1:53
Feb 3 16:02:23 MikroTik hotspot1: host 74:04:2B:2C:4A:F1/192.168.0.39 is blocked
Feb 3 16:02:31 MikroTik hotspot1: new host detected E0:2C:B2:09:A7:82/192.168.0.56 by UDP :22234 -> 8.8.8.8:53
Feb 3 16:02:31 MikroTik hotspot1: host E0:2C:B2:09:A7:82/192.168.0.56 is blocked
Feb 3 16:03:11 MikroTik hotspot1: new host detected 24:0A:64:16:EB:89/192.168.0.76 by UDP :57696 -> 192.168.0.1:53
Feb 3 16:03:11 MikroTik hotspot1: host 24:0A:64:16:EB:89/192.168.0.76 is blocked
Feb 3 16:03:12 MikroTik hotspot1: new host detected 8C:3A:E3:35:45:A6/192.168.0.72 by UDP :16228 -> 192.168.0.1:53
Feb 3 16:03:12 MikroTik hotspot1: host 8C:3A:E3:35:45:A6/192.168.0.72 is blocked
Feb 3 16:03:29 MikroTik hotspot1: new host detected 74:04:2B:2C:4A:F1/192.168.0.39 by UDP :43195 -> 192.168.0.1:53
Feb 3 16:03:29 MikroTik hotspot1: host 74:04:2B:2C:4A:F1/192.168.0.39 is blocked
Feb 3 16:04:08 MikroTik hotspot1: new host detected E0:2C:B2:09:A7:82/192.168.0.56 by UDP :14842 -> 192.168.0.1:53
Feb 3 16:04:08 MikroTik hotspot1: host E0:2C:B2:09:A7:82/192.168.0.56 is blocked
Feb 3 16:04:13 MikroTik hotspot1: new host detected 8C:3A:E3:35:45:A6/192.168.0.72 by UDP :2919 -> 192.168.0.1:53
Feb 3 16:04:13 MikroTik hotspot1: host 8C:3A:E3:35:45:A6/192.168.0.72 is blocked
Feb 3 16:04:22 MikroTik hotspot1: new host detected 24:0A:64:16:EB:89/192.168.0.76 by UDP :52663 -> 192.168.0.1:53
Feb 3 16:04:22 MikroTik hotspot1: host 24:0A:64:16:EB:89/192.168.0.76 is blocked
Feb 3 16:04:34 MikroTik hotspot1: static host 20:6E:9C:8D:8B:05/192.168.0.141 added, ip 192.168.0.141
Feb 3 16:05:03 MikroTik hotspot1: new host detected 00:F8:1C:33:F1:20/192.168.0.85 by UDP :16839 -> 192.168.0.1:53
Feb 3 16:05:03 MikroTik 00: F8:1C:33:F1:20 (192.168.0.85): trying to log in by mac
Feb 3 16:05:03 MikroTik 00: F8:1C:33:F1:20 (192.168.0.85): local user not found
Feb 3 16:05:03 MikroTik 00: F8:1C:33:F1:20 (192.168.0.85): login failed: invalid username or password
Feb 3 16:05:03 MikroTik hotspot1: static host 00:F8:1C:33:F1:20/192.168.0.85 added, ip 192.168.0.85
Feb 3 16:05:06 MikroTik KlaraZ (192.168.0.85): trying to log in by cookie
Feb 3 16:05:06 MikroTik KlaraZ (192.168.0.85): using profile <ziaci>
Feb 3 16:05:06 MikroTik KlaraZ (192.168.0.85): adding ip->user binding
Feb 3 16:05:06 MikroTik KlaraZ (192.168.0.85): logged in
WHY IS SOMEONE BLOCKED AND SOMEONE NO???
And what this “blocked” mean?
I have no active Firewall rules now because this, but there is no problem.
After restarting hotspot - no one is blocking. But only for a while…
Many Thx for all advice.
