Very strange problem here. I have an EOIP tunnel for traffic to a certain pre-defined server. Ping through EoIP is excellent under 50ms as expected. However web access is quite slow it’s like the response packet never got through. But, here’s the even stranger part, if I go to Tools/Packet Sniffer and run it on the EoIP interface suddenly web access speed will be perfect as expected. Anyone knows what’s going on here? I’ve been trying to solve this for the last week to no avail.
BTW, it’s not just EoIP, happens with VPN connection as well. The local internet connection works fine though.
Here’s my config:
[admin@MikroTik] > /interface print
# NAME TYPE ACTUAL-MTU L2MTU MAX-L2MTU MAC-ADDRESS
0 R ether1 ether 1500 1596 2026 6C:3B:6B:21:3A:BD
1 R ether2-master ether 1500 1596 2026 6C:3B:6B:BD:3A:22
2 RS ether3 ether 1500 1596 2026 6C:3B:6B:BD:3A:23
3 RS ether4 ether 1500 1596 2026 6C:3B:6B:BD:3A:24
4 S ether5 ether 1500 1596 2026 6C:3B:6B:BD:3A:25
5 R eoip-hk eoip 1438 65535 02:55:E0:ED:4C:7A
6 R pppoe-out1 pppoe-out 1480
[admin@MikroTik] > /interface eoip print
0 R name="eoip-hk" mtu=auto actual-mtu=1438 l2mtu=65535 mac-address=02:55:E0:**:**:** arp=enabled arp-timeout=auto
loop-protect=default loop-protect-status=off loop-protect-send-interval=5s loop-protect-disable-time=5m
local-address=local remote-address=remote tunnel-id=id dscp=inherit clamp-tcp-mss=yes
dont-fragment=no allow-fast-path=no
