Very very Low signal with RB751U-2HnD
I have RB751U-2Hnd it had good strength of signal but suddenly i see very low signal in even 8 meter it has very low signal on my laptop,
what is the problem anybody have suggestion?
best regards,
Anybody there? Please let me know what is the best way to solve this problem.
The signal is very very low!!!
I did reset factory but the problem is still exist.
Sent from my GT-I9300 using Tapatalk 2
Send your supout.rif file to support@mikrotik.com, we will check status of your device.
You can choose external antenna, choose a 3 -7 db is enough, big bad instead.if you want to know or choose more some antenna,you can visit the website:http://www.mobile4wifilte.co.uk/
Something happened to RB it was very good. It is not right way
