Very Weal Link
Hello I have built a Mikrotik Link with 2 PC(Pentium 3 866 Mhz 384 Sdram, 1 AMD Sempron 1,6 Ghz 256 DDRAM) and 2 Ubiquiti 400 mw SR5, and 2 parabolic dishes of 32 dbi.The distance is 7 Km and I can cary over the Link only 11,5 Mbps.The Link works in 5805 Ghz.I am very disapointed, the signal strength is -67 dbm, and the Link is is 11,5 Mbps I have very big pings(100 ms, 78 ms).Please help me with some advices what to do to cary more Mbps between the Link, because I think I have wrong somewhere.
Well, actually this is definitively a low link, I use MTK with a distance of 6kms with antennas and I obtain 24Mbps.
How is your environment?.
with That signal you should rock do you have some configaration to look at
Now work 52 megabits i change the frequency and i activate turbo mode.
I am the brother .
