veth deleted, cannot create new interface
I upgraded to 7.11.1 and my veth1 interface disappeared. When I try to re add it I get
[admin@RB5009UG+S+] > interface/veth/add name=veth1 address=10.21.65.2/32 gateway=10.21.65.1
failure: veth setup failed
I can add the interface without a gateway and then add the gateway later but it doesn’t route, nor does it survive reboot. Help!
BTW everything worked great before the upgrade. I tried downgrading to 7.11 and restoring my backup but the problem persists.
It may be enforcing that your gateway is outside the subnet’s range (e.g. container IP is /32 but should be /24). I’m guess the validity check is new, and upgrade removed it since it was “invalid” and why you can’t add either.
e.g.
like should be…
address=10.21.65.2/24
Thank you!
The same pattern occurs in 7.11 with gateway6 parameter. This fails:
/interface veth add address=192.168.45.200/24 gateway=192.168.45.1 gateway6=2001:470:8248:2d::e name=vbind9
This works:
/interface veth add address=192.168.45.200/24 gateway=192.168.45.1 name=vbind9
/interface veth set [ find where name=vbind9 ] address=192.168.45.200/24 gateway=192.168.45.1 gateway6=2001:470:8248:2d::e
and the export looks like:
/interface veth
then veth add fails at reboot.
Oy, this works:
/interface veth
add address=192.168.45.200/24,2001:470:8248:2d:c086:31ff:fe24:851a/64 gateway=192.168.45.1 gateway6=2001:470:8248:2d::e name=vbind9
Intuitively obvious but only if known.
Similar parameter check behavior for add and set would be nice.
Yeah, VETH used not check anything, and now it does check “more” but not everything… But does seem like it should be handled better/bug. e.g. not break on upgrade & gateway/gateway6 outside the container’s address= subnets should not be allowed
@Amm0 sigh
Create Network is so incomplete https://help.mikrotik.com/docs/display/ROS/Container#Container-Createnetwork
Tips and Tricks is only place IPv6 is shown https://help.mikrotik.com/docs/display/ROS/Container#Container-Tipsandtricks
IMO address parameter worst; it accepts (A) multiple addresses, (B) both IPv6 and IPv6, and neither is obvious.
I am so grateful your contributions here inspired that discovery. Thank you, thank you, thank you.
