I am traying to install adguard on container. Everything is working fine for the first time (CCR1009 as main router, and HAP ac2 as container for adguard) . After reboot (hap ac2) VETH loses IP address and everything is broken.
In field address says 0.0.0.0/0, and gateway is OK…like 192.168.32.1 for example.
It has been tried also on CCR1009 (without container and adguard - just plain VETH) and after reboot also loses IP - 0.0.0.0/0.
I don’t have such problem, but over Winbox VETH address field is always set to 0.0.0.0/0, must be careful to not accidentaly press Apply. If you enter correct address it will apply, but on next dialog open it will be again 0.0.0.0/0. It’s bug on GUI, it’s just wrongly presented. Over CLI is printed ok and there is no network problems in conteners after reboot. On Webfig similar issue, just address field is blank.
/interface/veth> print
Flags: X - disabled; R - running
0 R
name="veth1" address=192.168.254.2/24 gateway=192.168.254.1 gateway6=""
