Video over IP issue
I’m setting up several CRS354-48p-4s+2q switches and I’m seeing something I don’t understand.
Using tripp-lite hdmi to IP converters, (B162-100-POE and B162-001-POE) everything works as expected in SwitchOS. If I boot into RouterOS however, the switches will not pass video. as an experiment, I reset the config and the default config, configured a simple bridge, and still nothing.
There is obviously some setting I need to enable to make this work in RouterOS but I have no idea. Tried turning on IGMP snooping as the video converter manuals mention the switch needs to support igmp, but no change.
Thanks in advance.
FYI, got no reply here, but found the answer over on reddit. Jumbo Frames l2mtu 10024? (don’t remember exactly) mtu 9000 fixed the issue.
