Video Streaming Issue in CCR 1036 Router Board
Dears,
I am using Mikrotik CCR1036-12G-4S Cloud Router for my WISP setup.
Following works are configured in my CCR.
BGP Routing, Using basic( be Default ) Queues for bandwidth Management only.
I have around 60Mbps Bandwidth from my Main stream provider, the problem is Video Streaming too slow or buffering, if even try in Youtube or any live Streaming websites, however if I check the bandwidth through FTP or putting number of download I am able to get full bandwidth without any problem same way uplink, the only issue is Slow Video Streaming behind the CCR Router, if I connect directly the Main Stream Provider connection to my PC it works perfect.
Need Your advise for this.
Still I am using version 6.3.
explain your Queue bandwidth management setup.
Simple Queues using.
for example… Given the IP address in Target, and assigning Target upload and Download.
Waiting for Feedback please…
I have seen similar but can’t narrow it down using 1036 as pppoe Concentrators simple queues setup automatically by radius attributes…
Anyone else seen this
On 6.24 I think
Respected Seniors and Mikrotik Expert, Please advice with prompt response, I am really in a big trouble.
Are you using SFP? Is the firmware up to date? Which ROS version?
A solution for this ?
Using radius for dynamic queues.
Yes. Using 10G+.
Latest routeros
Hello friend, I have the same problem, you found the solution
Kinda..
Radius uses simple queues; default-small - pfifo.
I’ve tried modifying the Queue size to 2000 and everything’s kinda okay mate.
Got a 1072 so RAM’s sorted :slight_smile:
Anyone with a better solution, Shed light :wink:
