Video surveillance over Wireless
Greetings,
I require some advices on setting up surveillance wireless network. We’ve already setup 2 APs OmniTIK U-5HnD,
8 SXT 5HPnD connected to 11 cameras .
It seems that these APs weren’t adequate for the task, as we experienced instability which was solved by lowering res on cameras.
Btw we need 1080p res on all cameras.
Any advice is appreciated.
PS: Sorry I don’t have all technical information, I am just a bystander watching technicians trying to troubleshoot it.
Thanks :slight_smile:
basically with this equipment u shouldn’t have any problems - I m not sure how much u are in to Mikrotik
But If u can find out how much throughput need one cam with 1080p res
Did u do btest from Sxts to Omnitik?
Upgrade ur MT gear to v5.22
Have u tried using nv2 or nstreme?
If its close range like <100m from SXT to OmniTIk lower SXT Tx power - 5HPnD are very powerful 31dB, signal should be something like -55/-60 maybe more
at the end :slight_smile: there can be million things that can case a problem..
