video surveillance
Hello
Does anybody have any experience with video surveillance with Microtik equipment and what equipment you can recommend for distance around 7 miles
Thank you .I appreciate your help
Imperium
We have a customer running 16 cameras on his like and monitoring them remotely. Not sure what you mean by the 7 miles the rf link or something else.
Erik
Eric
I would like to have remote control over wirelles.
High speed dome camera will be on top of hill above our
town ,on tower for TV and Radio stations
Hill is on around 600 meters oversea level.Two points
where we would like to receive video signal are in the town.On one point we will have
DVR(Digital video recorder) with for control keyboard(for PTZ) and on another we would like to receive video signal on
PC.Also do you have idea which cameras I can use to transmit RS-485 signal
Thank you for your help
imperium
You do want to go with a IP camera, for the install you described, you are also looking at a high end camera to get much out of the picture is my guess.
Try http://www.axis.com large selection of low to mid level camera
http://www.iqeye.com some high end stuff.
Erik
here: http://www.tiktube.com/2007/06/21/wireless-surveilence-systems-by-edward-neef/
and: http://mum.mikrotik.com/presentations/2007_1/PL07_Neef.pdf
Edward Neef talks about wireless surveilence with MikroTik
Erik
I would like to use both IP and analog cameras
When I using analog cameras will use encoder and decoder
The biggest problem is network between two points.I do not now which microtik equipment will be the best for this solution
thank you for your comments
the answer is YES mikrotik will do what you need, perfectly.
you need to read up more on MT and how to use it.
but the answer is yes, mt will work for what you want..and better than any other solution… beyond that you need to do some testing and research..no one here will guide you step by step.
Jo2Jo
Thank you for your comment
I did not ask anybody to show me something step by step
Can you tell me first point or recommend something
What you think about Mikrotik RIC/522 Outdoor Wireless Router 5.1 - 5.9GHz
Is this good point to start researhing
I appreciate your comments
Imperium
