View Current Tx Power on AC
Hello everyone,
I have been setting my transmit power manually for quite some time, but want to start using the regulatory-domain settings instead. I just want to verify what the transmit power is actually being set to so that it can be logged and reported accurately in our coverage map and path analysis applications. Normally on non-ac equipment I would just view the Current Tx Power tab right in winbox, however ac doesn’t display this information. Does anyone know if this information can be read through terminal?
I found it, when operating in regulatory-domain you can look under the status tab. It will now display your transmit power in line with Channel.
