View DNS query
Is there any way to view which DNS server Mikrotik is querying? Like an NSLOOKUP command equivalent? I’d like to check whether it is using the DNS server I have specified.
Thanks,
Jeroen
Not directly. Of course you can use torch or traffic capture or even just a filtered view of the IP firewall connections to see the destination address of DNS packets that have the router as the source.
It doesn’t really have a choice, though. Whatever servers are listed in “/ip dns” are the only DNS servers the router knows about.
Capturing traffic kind of worked (good enough for confirmation purposes). Every time I trigger an NSLOOkUP from my workstation, the IP of OpenDNS is queried. I see an “IN” and and “OUT” packet so that would be request and response (reply).
Perhaps I could try a port mirror and connect a Wireshark equiped computer to the mirror-port if I really want to see the full DNS-response.
So thanks Fewi, packet capturing suffices. My ISP’s DNS servers stop certain website from loading completely. A bit weird but using OpenDNS solves this:)
