So basically you want to be able to use a server on the lan to show images >
When you say clients do you mean people on the internet (external WANIPs)?
RouterOS can’t be used as webserver for your own files. It would be simple to add for MikroTik, because there obviously is webserver already, but you’d have to convince them first that it’s good idea. Until then, your only chance is to try to find some way how to misuse hotspot, but I don’t know if it’s possible.
Imagine there is a monitor where users press the word “zebra” and the image of a zebra appears in the monitor.
This monitor will be in the specific LAN created by a RB951 (or 941).
The images will be shown locally not through public IP’s.
(there is reason for not having the images in the monitor)
I know that if i use the hotspot and run the html through the login page i can have almost what i want but that way i have to write a lot of HTML lines…
I was curious about it cause if for example you type (gateway ip):hotspot/img/password.svg you can see the password image in your browser.
The default hotspot password image. And the user.svg image as well..
And if you type /file print in the Terminal you can see the Hotspot file and its contents but not a file i have created and uploaded the images.
e.x.
Image (file)
zebra. png
I can confirm what you see, existing files in hotspot directory are accessible, but when I upload some new one, then nothing, just 404. But hotspot pages are customizable, you can download different templates and they do include images. It must be something simple, but I don’t know what, I never really used hotspot.
