View voltage value on routerboard from PRTG monitoring
Hello all,
we can view battery voltage on RB with winbox (system - health).
Now, I would like to view this voltage value without opening my winbox, but using monitoring device (PRTG) instead.
Is this possible to do? if yes, How to make system-health can be monitored by monitoring device, such as PRTG?
Pls advise
many thanks b4
You can monitor voltage with SNMP.
Run in console “/system health print oid” command and then set up your monitoring software to monitor voltage OID
mrz,
many thanks, I will try your advise
rgds
