Viewing IP cameras on VPN client
Hi there,
I`m a Mikrotik beginner. I have two branches connected via Mikrotik PPTP VPN. There are two IP cameras on one branch connected directly to (Vigor) router. They can view them trough http protocol. What should I set on the Mikrotik router that I can access them from my local network? Thanks.
are you saying the cameras work on tcp/80? If so, just route or allow tcp/80. But if they are UDP RTSP streams, then you will need non-masq’d routes to view them.
TO access them through any local network you need to type http://IP address of your IP camera and download the Active X. If you rae having Dynamic IP then there might be issue.
Hope this would help..
