viewing NAT mappings
Apologies for the dumb question, but after searching about I have found nothing useful.
I have setup a RB750 as the gateway on our network with firewalling, NAT, Queues and some VPN’s etc. (Mostly put together from posts on the wiki and other sources)
Things are working nicely, but in my queues I am seeing that an inordinate amount of traffic is coming through as “other” meaning my mangle rules are not classifying it before the “other” rule..
I want to track this down so it can be classified properly and prioritised/limited according to what it is, so I created a new mangle rule before the “other” rule to just log this data. It now gives me all the traffic goiing between various sources on the web and my external ip address (because of being natted) and the ports vary a lot.
I need to be able to see what NAT is mapping to to be able to figure out what this traffic is and a way of classifying it properly and I can’t seem to find it anywhere.
If someone can point me in the right direction I would be very grateful.
look at http://wiki.mikrotik.com/wiki/Packet_Flow
for example, ‘Mangle Prerouting’ is before ‘Destination NAT’, so you see raw packets. use ‘forward’ instead
