Virtual AP on client
Maybe a stupid question. I just want to know if its possible to make a virtual AP on a client in station mode?(on the same card). I already tried, and it says running, but I can’t connect to it.
Guess I can use WDS, but I want to route between the interfaces. Allready checked out the manuel, but I didnt see anyting there that gave me any ideas.
The equipment is a RB 511 with a AR5413.
It is not possible to use Viraual AP if the master interface is in station mode. You should use AP or bridge mode and use WDS in your system. You can use routing on wds interfaces if you don’t want to use bridging.
Ok thanx. Thought is was something like that. Will try that what no-one is online.
