drmark
December 16, 2012, 5:10am
1
I followed this guide for setting up a virtualAP (page 13)
http://mum.mikrotik.com/presentations/ID08/nicholaus_ufoakses.pdf
and I do have the virtualAP transmitting, however, I cannot connect to the virtual AP - devices attempting to connect do not seem to be receiving any network assignments.
In other readings I came across this comment
Did you set the master-interface=wlan1 (or whatever interface)?
Did you enable the VAP interface?
Did you put a DHCP server on it?
http://forum.mikrotik.com/t/viratual-ap-manual/20749/1
I did the first two points, but I do not know how to do the third - how is this done?
I would also like the virtual AP to use the same network range as the WLAN.
normis
December 17, 2012, 9:05am
2
please pase the output of command “/export compact” so we can check your config.
drmark
December 17, 2012, 7:24pm
3
Looks like I’m missing some aspects of setting up the interface
(Then set it up like any other interface, with its own ip/subnet and dhcp server.)
http://forum.mikrotik.com/t/2-ssids-on-751u/53876/1
here is the config
# dec/17/2012 10:40:20 by RouterOS 5.22
# software id = F34F-6D0J
add admin-mac=D4:CA:6D:4F:D0:1E auto-mac=no l2mtu=1598 name=bridge-local \
protocol-mode=rstp
/interface wireless
set 0 band=2ghz-b/g/n channel-width=20/40mhz-ht-above disabled=no distance=\
indoors frequency=2422 ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=\
ap-bridge ssid=SSID1 wireless-protocol=802.11
set 0 mac-address=00:2C:42:5A:31:48 name=sfp1-gateway
set 1 name=ether1-gateway
set 6 name=ether6-master-local
set 7 master-port=ether6-master-local name=ether7-slave-local
set 8 master-port=ether6-master-local name=ether8-slave-local
set 9 master-port=ether6-master-local name=ether9-slave-local
set 10 master-port=ether6-master-local name=ether10-slave-local
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
wpa-pre-shared-key=password1 wpa2-pre-shared-key=password1
add authentication-types=wpa2-psk management-protection=allowed name=virtualAP1 \
wpa2-pre-shared-key=password2
/interface wireless
add area="" arp=enabled bridge-mode=enabled default-ap-tx-limit=0 \
default-authentication=yes default-client-tx-limit=0 default-forwarding=yes \
disable-running-check=no disabled=no hide-ssid=no l2mtu=2290 mac-address=\
D4:CA:6D:4F:D0:1E master-interface=wlan1 max-station-count=2007 mtu=1500 \
multicast-helper=default name=virtualAP1 proprietary-extensions=post-2.9.25 \
security-profile=virtualAP1 ssid=SSID2 update-stats-interval=disabled \
wds-cost-range=0 wds-default-bridge=none wds-default-cost=0 \
wds-ignore-ssid=no wds-mode=disabled wmm-support=disabled
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add address-pool=default-dhcp disabled=no interface=bridge-local name=default
/queue simple
add burst-limit=768k/5M burst-threshold=768k/5M burst-time=1s/1s max-limit=\
768k/5M name="Kid01 Day" target-addresses=192.168.88.240/32
768k/5M name="Kid0000000002 Day" target-addresses=192.168.88.242/32
add burst-limit=1k/1k burst-threshold=1k/1k burst-time=1s/1s disabled=yes \
max-limit=1k/1k name="Kid01 Night" target-addresses=192.168.88.240/32
max-limit=1k/1k name="Kid0000000002 Night" target-addresses=\
192.168.88.242/32
add bridge=bridge-local interface=ether2
add bridge=bridge-local interface=ether3
add bridge=bridge-local interface=ether4
add bridge=bridge-local interface=ether5
add bridge=bridge-local interface=ether6-master-local
add bridge=bridge-local interface=wlan1
add address=192.168.88.1/24 comment="default configuration" interface=wlan1
/ip dhcp-client
add comment="default configuration" disabled=no interface=sfp1-gateway
add comment="default configuration" disabled=no interface=ether1-gateway
/ip dhcp-server lease
add address=192.168.88.240 client-id=1:e8:39:df:f3:45:d0 mac-address=\
E8:39:DF:F3:45:D0 server=default
add address=192.168.88.242 client-id=1:e8:39:df:f3:31:80 mac-address=\
E8:39:DF:F3:31:80 server=default
add address=192.168.88.243 client-id=1:0:26:6c:86:92:49 mac-address=\
00:26:6C:86:92:49 rate-limit=1k server=default
add address=192.168.88.241 client-id=1:0:26:6c:86:91:b9 mac-address=\
00:26:6C:86:91:B9 rate-limit=1k server=default
add address=192.168.88.0/24 comment="default configuration" dns-server=\
192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=\
sfp1-gateway
ether1-gateway
add action=masquerade chain=srcnat comment="default configuration" \
out-interface=sfp1-gateway
out-interface=ether1-gateway to-addresses=0.0.0.0
add action=dst-nat chain=dstnat dst-port=53 protocol=tcp src-address=\
192.168.88.240 to-addresses=208.67.222.123 to-ports=53
add action=dst-nat chain=dstnat dst-port=53 protocol=udp src-address=\
192.168.88.242 to-addresses=208.67.222.123 to-ports=53
/ip neighbor discovery
set sfp1-gateway disabled=yes
set ether1-gateway disabled=yes
set wlan1 disabled=yes
set virtualAP1 disabled=yes
/system clock
set time-zone-name=America/Edmonton
/system ntp client
set enabled=yes mode=unicast primary-ntp=132.246.11.229
/system scheduler
add interval=1d name="Kids Day" on-event=Day policy=read,write start-date=\
dec/16/2012 start-time=05:30:00
add interval=1d name="Kids Night" on-event=Night policy=read,write start-date=\
dec/16/2012 start-time=21:05:00
/system script
add name=Day policy=read,write source="/queue simple enable \"Kid0000000002 Day\
\"; /queue simple disable \"Kid0000000002 Night\"; /queue simple enable \"Ki\
d01 Day\"; /queue simple disable \"Kid01 Night\""
add name=Night policy=read,write source="/queue simple enable \"Kid0000000002 Ni\
ght\"; /queue simple disable \"Kid0000000002 Day\"; /queue simple enable \"K\
id01 Night\"; /queue simple disable \"Kid01 Day\""
/tool mac-server
add disabled=no interface=ether2
add disabled=no interface=ether3
add disabled=no interface=ether4
add disabled=no interface=ether5
add disabled=no interface=ether6-master-local
add disabled=no interface=ether7-slave-local
add disabled=no interface=ether8-slave-local
add disabled=no interface=ether9-slave-local
add disabled=no interface=wlan1
add disabled=no interface=bridge-local
/tool mac-server mac-winbox
add interface=ether2
add interface=ether3
add interface=ether4
add interface=ether5
add interface=ether6-master-local
add interface=ether7-slave-local
add interface=ether8-slave-local
add interface=ether9-slave-local
add interface=wlan1
add interface=bridge-local
uldis
December 18, 2012, 7:57am
4
if you want that virtual AP to be in the same network where other wireless interface and ethernet then you need to add virtual APs interface virtualAP1 into the bridge ports.
drmark
December 19, 2012, 5:05pm
5
thank you for the solution
