I recently got this mikrotik Metal 2SHPn in which will function as access point for internal use (192.168.88.0/24) and virtual access point for public use (192.168.33.0/24.)
This Metal is connecting through the main router on port 5 (main router network is all 192.168.88.0.24.) Currently the Metal is setup as bridge mode with the following configuration:
# mar/18/2016 18:02:11 by RouterOS 6.30.4
# software id = UCC1-CYM5
add name=bridge-gue
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country=indonesia disabled=no frequency=auto l2mtu=1600 mode=ap-bridge ssid=money wireless-protocol=802.11
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=youbetgot wpa2-pre-shared-key=youbetgot
add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=allowed name=guest-profile supplicant-identity=""
/interface wireless
add disabled=no l2mtu=1600 mac-address=E6:8D:8C:F8:03:83 master-interface=wlan1 name=guest-wlan security-profile=guest-profile ssid=money-guest wds-cost-range=0 \
wds-default-cost=0
add name=guest-pool ranges=192.168.33.11-192.168.33.254
add address-pool=guest-pool disabled=no interface=guest-wlan name=guest-dhcp
add bridge=bridge-gue interface=wlan1
add bridge=bridge-gue interface=ether1
add address=192.168.88.3/24 interface=ether1 network=192.168.88.0
add address=192.168.33.1 interface=guest-wlan network=192.168.33.0
/ip dhcp-client
add dhcp-options=hostname,clientid interface=bridge-gue
add address=192.168.33.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.33.1
add action=masquerade chain=srcnat src-address=192.168.33.0/24
add distance=1 gateway=192.168.88.1
/system clock
set time-zone-name=Asia/Jakarta
/system identity
set name="Anak Metal"
/system routerboard settings
set protected-routerboot=disabled
/tool romon port
add
Now the if I connect to the “money” (internal,) I can access internet just fine. However if I connect through the “money-guest” it’s cannot even though it’s getting ip address. Is there anything I can do on either the Metal or the main router? Thank you so much!
