Virtual-AP with Vlan tagging
Is it possible to tag packets with certain tag in Vitrual-AP, for example three Virtual-APs with different Vlan tags in the routerboard configured as a bridge ?
Regards
Faton
OK I’ve got it working, very simple:
Create Vlan interfaces with appropriate vlan IDs, than create Virtual-APs with appropriate SSIDs, after this create bridge interfaces and add Vlan and Virtual-AP to desired bridge, but never add Ethernet or Wireless interface to a bridge, aslo you should not configure trunk in cisco switch with native vlan 1, but with any other vlan.
Regards.
Faton
can you test performance? Im curious to see if that bridge affects total throughput. It would be nice to just be able to specify a vlan ID on the wireless interface itself.
that would be perfect, reason why I asked about this configuration was that ethernet of my Cisco 1200AP just died, so I had to replace it fast with something robust as such, but the difference is that in Cisco AP you can specify Vlan ID in wireless interface. By the way I will let you know about the performance of this setup.
Regards.
Faton
We use all sorts of bridges and vlans all the time. There is no impact on throughput.
I also like the way it is now with bridges and vlans and virtual interfaces - it is far more customizable and flexible.
