How many Virtual AP’s can you have?
I have a AP that has 2 V-AP’s and when I add a 3rd I lose all my clients on all other AP’s
Using on this unit CM9 and 2.8.27
I found in the manual that you can have up to 7 VAP’s
Does anyone have more than 2 VAP’s running.
I am trying to add a 3rd VAP and when I do, all my registered users go away.
I don’t think there is any hard limit for the number of virtual APs.
John
7 VAPs is the max you can add to one WLAN interface, just tested that. Not sure if they all work though.
Which version?
v2.8.9 on a routerboard 532
