Hi guys, I’m trying to figure out how to run an open hotspot (as the virtualap) along with an encrypted private network, I think I’ve got most of the stuff correct but somehow the private network doesn’t want to work eg. no internet connectivity but I do get an IP address. For some odd reason only my android phone works, iphones, win 8 tablet and macbook wont work on it.
Might it have to do with firewall rules for the hotspot? They dont seem to get exported.
v2.rsc
# may/15/2015 11:44:41 by RouterOS 6.21.1
# software id = JMA5-T5NA
add name=private_bridge
add name=wds-bridge
set [ find default=yes ] eap-methods="" interim-update=1m \
radius-mac-accounting=yes supplicant-identity=MikroTik
add authentication-types=wpa2-psk eap-methods="" management-protection=\
allowed mode=dynamic-keys name=private_profile supplicant-identity="" \
wpa-pre-shared-key=00000000 wpa2-pre-shared-key=00000000
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode \
band=2ghz-b/g country="south africa" dfs-mode=no-radar-detect disabled=no \
frequency=auto frequency-mode=regulatory-domain l2mtu=2290 mode=ap-bridge \
security-profile=private_profile ssid=Test wds-default-bridge=wds-bridge \
wds-mode=dynamic wireless-protocol=802.11
add disabled=no l2mtu=2290 mac-address=4E:5E:0C:BE:36:4B master-interface=\
wlan1 name=hotspot_ap ssid="Test HS" wds-cost-range=0 wds-default-cost=0
/ip hotspot profile
add dns-name=hotspot.xxx hotspot-address=10.1.1.1 http-proxy=\
0.0.0.0:8080 login-by=http-chap name=hsprof1 radius-interim-update=10m \
use-radius=yes
add name=dhcp ranges=10.10.1.2-10.10.10.254
add name=no-https ranges=10.10.21.1-10.10.30.254
add name=wds ranges=10.10.20.1-10.10.20.254
add name=private-pool ranges=192.168.10.2-192.168.10.254
add address-pool=dhcp disabled=no interface=wds-bridge lease-time=30m name=\
hotspot_dhcp use-radius=yes
add address-pool=private-pool disabled=no interface=private_bridge name=\
private_dhcp
/ip hotspot
add address-pool=dhcp disabled=no idle-timeout=none interface=wds-bridge \
name=hotspot1 profile=hsprof1
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=no address-pool=dhcp \
keepalive-timeout=1h rate-limit="100k/1M 100k/2M 100K/512k 10/10" \
session-timeout=2h shared-users=unlimited
/system logging action
set 2 remember=yes
add bridge=wds-bridge interface=hotspot_ap
add bridge=private_bridge interface=wlan1
add address=10.10.1.1/16 interface=wds-bridge network=10.10.0.0
add address=192.168.10.1/24 interface=private_bridge network=192.168.10.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
add address=10.10.0.0/16 dns-server=10.10.1.1,8.8.8.8,8.8.4.4 gateway=\
10.10.1.1
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
/ip hotspot user
add name=hotspot-user password=123456
/ip hotspot walled-garden
add comment="place hotspot rules here" disabled=yes
add dst-host=*.google-analytics.com
add dst-host=*.akamaihd.net
add dst-host=xxxxx
add dst-host=xxxxx
add dst-host=xxxxx
add dst-host=xxxxx
/ip hotspot walled-garden ip
add action=accept disabled=no dst-port=443 protocol=tcp src-address=\
add action=accept disabled=no src-address=10.10.20.1-10.10.20.254
/ip proxy
set enabled=yes
/ip upnp
set allow-disable-external-interface=no
/radius
add address=xxx.163 secret="xxxx" service=\
hotspot,wireless,dhcp timeout=600ms
/snmp
set trap-community=public
/system clock
set time-zone-name=Africa/Johannesburg
/system identity
set name=4AC704F9643D
/system leds
set 5 interface=wlan1
/system ntp client
set enabled=yes primary-ntp=196.25.1.9 secondary-ntp=41.216.204.3
/system scheduler
*scripts to check if router is online and send updates to router*
/tool graphing interface
add
/tool graphing queue
add
/tool graphing resource
add
Above is the config with all confidentials edited.
