Virtual APs and CPU
I need to use the same radio to:
  • Connect about 30 hotspot costumers. (All with NS5 and NAT in the NS5 ethernet)
  • Connect 4 remote repeaters to make the same 5 KM away. RBs with 2 radio, 1 receiving and 1 repeating in different freq..
    (I have my costumers in a mountain area without direct LOS, for this reason I’m doing repeaters..)
Then I’m thinking in:
  • Use the main wlan1 to create a hotspot and connect there all the costumer NS5’s.
  • Create one WDS associated to this wlan1 for each repeater. (4 in total).
My questions are:
  • This will work without isues?
  • If you use “a lot” of Virtual APs, the CPU is higher than if you use only the main wlan?
  • I need to create another virtual AP for the hotspot users and let the real wlan without nothing associated directly to it?
    Thanks,
I do not think that Virtual AP should make extensive load on your CPU.
Additional Virtual AP will be just as additional wireless interface, but using the same frequency.
Ok, perfect. Thanks sergejs!
