Virtual Ethernet Problem.
I tried to add a Virtual Ethernet and it gave me an error saying that “the feature is not implemented”. And since then i dont see any of my Ethernet Interfaces in “Interfaces” section.
Also when i try to add a firewall rule and when i try to select interface it only says “unknown” none of my interface is there.
Same thing is there in “/ip addresses”
What should i do here. How to resolve this issue.
/ interface export
set 0 arp=reply-only auto-negotiation=yes cable-settings=default comment="" disable-running-check=yes disabled=no \
    full-duplex=yes mac-address=00:0C:F1:FD:0A:16 mtu=1500 name=LAN speed=100Mbps
set 1 arp=enabled auto-negotiation=yes cable-settings=default comment="" disable-running-check=yes disabled=no \
    full-duplex=yes mac-address=00:0C:F1:FD:0A:11 mtu=1500 name=LDN speed=100Mbps
set 2 arp=enabled auto-negotiation=yes cable-settings=default comment="" disable-running-check=yes disabled=no \
    full-duplex=yes mac-address=00:08:74:41:FA:B2 mtu=1500 name=PTCL speed=100Mbps
/interface pppoe-client
add ac-name="" add-default-route=yes allow=pap,chap,mschap1,mschap2 comment="" dial-on-demand=no disabled=no interface=\
    PTCL max-mru=1480 max-mtu=1480 mrru=disabled name=ptcl password=xxxxxxxx profile=default service-name="" \
    use-peer-dns=no user=xxxxxxxxx
add ac-name="" add-default-route=no allow=pap,chap,mschap1,mschap2 comment="" dial-on-demand=no disabled=no interface=LDN \
    max-mru=1480 max-mtu=1480 mrru=disabled name=ldn password=xxxxxxxx profile=default service-name="" use-peer-dns=no \
    user=xxxxxxxx
set default authentication-types="" eap-methods=passthrough group-ciphers="" group-key-update=5m interim-update=0s \
    management-protection=disabled management-protection-key="" mode=none name=default radius-eap-accounting=no \
    radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX \
    radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none static-key-0=\
    "" static-key-1="" static-key-2="" static-key-3="" static-sta-private-algo=none static-sta-private-key="" \
    static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=none tls-mode=no-certificates unicast-ciphers=\
    "" wpa-pre-shared-key="" wpa2-pre-shared-key=""
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
/interface ethernet mirror
set
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=\
    disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=default enabled=no keepalive-timeout=60 \
    mac-address=FE:03:B1:3F:32:16 max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pppoe-server server
add authentication=pap,chap,mschap1,mschap2 default-profile=default disabled=no interface=LAN keepalive-timeout=10 \
    max-mru=1480 max-mtu=1480 max-sessions=0 mrru=disabled one-session-per-host=yes service-name=Crystal
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1460 \
    max-mtu=1460 mrru=disabled
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=\
    300 frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 multiple-channels=no only-headers=no receive-errors=no \
    streaming-enabled=no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
Help me resolve this issue.
disable/remove ‘xen’ package?..
Dear XEN package is not installed.
make supout.rif and send to support@mikrotik.com
p.s. reboot doesn’t help?..
