Virtual Interfaces ?
Does Router OS have the ability to create virtual interfaces (sub-interfaces) as you can with Cisco? I need the ability to create and bridge virtual interfaces across physical ethernet interfaces. You can do this with VLANs but in my scenario, the equipment at the other end of the link can not terminate a VLAN, thus I need an untagged virtual interface. Is there anyway to do this with Router OS?
can you use a bridge with a single port in it, and then assign that bridge an IP ? not really sure if that’s the right way but it sounds like it might work.
I need to use the main interface as well as virtual interface on both of the physical interfaces. Thus, I think the only solution is a real virtual interface.
