Hi, i have a dedicated server on Ionos with Proxmox.
Server wan interface is enp35s0
Has a public ip 217.xxx.xxx.10/32
Gateway 10.255.255.1
I have an additional ip address that ionos delivered me via vlan1010 for using it in virtual machine.
217.xxx.xxx.164/32
My /etc/network/interface:
auto lo
iface lo inet loopback
auto enp35s0
iface enp35s0 inet static
address 217.xxx.xxx.10/32
gateway 10.255.255.1
#Wan
iface enp36s0 inet manual
iface enx2ecbfb84894d inet manual
auto vmbr0 <-----RouerOS has his ether1 in this bridge with ip 217.xxx.xxx.164/32 and work it can go in internet and receive all ports and protocols
iface vmbr0 inet manual
bridge-ports vlan1010
bridge-stp off
bridge-fd 0
post-up ip link set vmbr0 promisc on
post-down ip link set vmbr0 promisc on
#Br-Wan
auto vmbr1
iface vmbr1 inet manual
bridge-ports none
bridge-stp off
bridge-fd 0
bridge-vlan-aware yes
bridge-vids 2-4094
#Br-VMs
auto vlan1010
iface vlan1010 inet manual
vlan-raw-device enp35s0
In RouterOS CHR i am able to receive gre connection, i have set a pptp server and from a remote side i am able to connect on it with a pptp client, seems everything work ok except EoIP tunnels… in ip firewall connections i can see outgoing eoip gre connection stuck in “confirmed state”. I don’t have any in/out firewall rule but cant see any incoming connections.
I have read around about try to set Promiscuous Mode in interfaces and bridges for solve this problem, i have do some test but still not work ![]()
Is my first time approaching promiscuous mode on linux, the interfaces seems to be in promiscuous mode right?
root@proxmox:~# ip a | grep PROMISC
2: enp35s0: <BROADCAST,MULTICAST,PROMISC,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
6: vlan1010@enp35s0: <BROADCAST,MULTICAST,PROMISC,UP,LOWER_UP> mtu 1500 qdisc noqueue master vmbr0 state UP group default qlen 1000
7: vmbr0: <BROADCAST,MULTICAST,PROMISC,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
8: tap100i0: <BROADCAST,MULTICAST,PROMISC,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master vmbr0 state UNKNOWN group default qlen 1000
Thank You.
