Is there a chance into one miktorik router to make more Virtual Routers.. Also this is Great to Update into new relase of MIkrotik Router OS, beacouse with this there are moe posibility.
Like the situation below where i have write a topic about PPPOE situation.
With virtual router includet into Router OS we can make it possible.
Or anyone who is interesed in the PPPOE problem can analyse and Make a replay.
eth1
Router OS LAN
ISP defalut gateway /-ppoe1--192.168.0.1\ eth2 /- 10.0.0.10-20
--192.168.0.254-------pppoe2--192.168.0.2 - 10.0.0.1---> HUB/Shwich--><--- 10.0.0.21-30
\-pppoe3-192.168.0.3/ \- 10.0.0.31-40
OR for pppoe client I can get the separate ethernet card
|------------- router OS ------------|
pppoe ethernet cards LAN
ISP defalut gateway /-ppoe1---192.168.0.1- eth1\ eth4 /- 10.0.0.10-20
--192.168.0.254------- pppoe2--192.168.0.2- eth2 - 10.0.0.1-->Hub/switch-->-<---10.0.0.21-30
\-pppoe3--192.168.0.3- eth3/ \- 10.0.0.31-40
Like you can see Lan PC with IP address 10.0.0.10 to 10.0.0.20 to get access to the internet from PPPoe1 and also others PC.
When pppoe1 connects to the ISP he gets the default gateway 192.168.0.256 also and other pppoe clients have the same gateway and beacouse of this i cannot source NAT LAN
Please if anyone know how to make this possible it will be great.
like this works Prosum WooWeb pro , hw makes a virtual lan and throgh this lan he manages the connections.
why does this all happen in the same subnet? make a new subnet for each of your networks, and a different GW for each group of users. the problem will disappear.
the gateway of the PPPOE client I cannot Controll beacouse this gateway is from ISP, Also if i Need to make more gateway in the LAN than i Need 4 Mikrotik OS routers.
