virtual SSID traffic with VPN
Hi Everyone,
I am using the hAP ac (model: RB962UiGS-5HacT2HnT) https://mikrotik.com/product/RB962UiGS-5HacT2HnT, it is now using the most basic default config, ether1(1st port) connected to ISP, two default SSID (wlan1 2.4GHz + wlan2 5GHz) created by default, for the wired LAN, there is only 1 PC connected to the ether2(2nd port), DHCP IP pool between 192.168.100.201-230
I have a VPN connection that already configured and connected in the router itself, the next step I would like to create a new virtual SSID, so any devices connected to this new SSID, all their traffic will go through the VPN connection established.
Sorry that I do not have much experience on command line interface, could anyone please advise me the steps by steps / procedure based on winbox interface?
Many thanks in advanced.
If the virtual wifi (WLAN) is on its own subnet or vlan anything is possible.
Hi, thanks for replying.
May I know the step by step creating this in Winbox please?
Thanks!
