Hi
I have two virtual wireless APs … one is part of the bridge, the other not (guest WLAN)
The Guest AP shows only “R”, the other one (part of the bridge) shows “RS” …
Is this because of the bridge ?
thx, Richard
Hi
thx, Richard
Yes It’s because of bridge, if you leave mouse some second over letters you will see R - Running, means that Interface (in your case Guest AP) is running and RS - Running Slave, means that your interface is Running and Slave of Bridge!
thx for the info !
Richard
