Virtual.??
I am bringing referring Virtual … May I change my Janelle one mention of Virtual ..?
Yes.
But all virtual APs on one physical radio will share the same frequency.
Ok ok
Which means that he Virgral depends on Channel One ..? I can not install each Virtual Channel Set …?
Install additional radio card and you can use other frequency simultaneously with the first radio. One radio means only one frequency at once.
