VirtualBox
I’ve searched for what I can on virtualization and it is clearly over my head. I’d like to know if the following scenario is even possible. If so, I can hunt down a consultant.
XP Machine
Two Ethernet Intrerfaces
One Wifi Interface
Is it possible to install RouterOS as a VirtualBox installation and then configure the interfaces as you would a regular router board? For example, ether1 as dhcp-cl enabled WAN interface. Ether2 a LAN interface, with dhcp-server installed. DST-NAT to devices connected to the LAN interface. Masquerade etc?
Thanks.
yes, that is doable.
