vista can ping hostname but cant browse
hi all mikrotik developers i have so much headache here regarding this issue im using rb150 or some sort of bugs?, is there anyone here encounter in vista you can ping hostname like (ping yahoo.com) but u cant browse and the rest XP users here no problem it works fine, if there anyone experience this issue pls help me to resolved this problem
thanks and much appreciated
iwantlemonjuice
I assume you tried disabling the firewall, and rebooting the Vista PC? Vista sometimes has issues with DHCP, you need to disable/enable the interface or reboot the PC to make it accept the new DHCP information.
hi normis thanks for support it works but i will observed as of now.
regards and thanks
iwantlemonjuice
