Vivato Unit
I have an old-school vivato 802.11b and had to reset the unit. Is there a user manual anywhere on the web?
This is a Mikrotik forum, maybe you should try http://www.vivato.com/
I have tried but no response from tech support at Vivato. I was hoping someone would have a copy of the user manual
If you have a 11b only unit, you should be able to connect to the comm port and login to the CLI. After a reset the login is “admin” and the password is “vivato”. Type a question mark “?” which will list all commands at that level.
thanks, got it configured
