networking level from 1 to 10, i am in number 2
i have a RB952Ui-5ac2nD using it as HOME AP DUAL ( in quick set )
when i plug the RB952Ui and connect ETH1 ( WAN ) to the wall
i did not get any ip on the WAN interface
so i asked the IT guys on the office and he told me that they use VLAN 100 as default
im using winbox
so i added VLAN100 to eth1 under interfaces menu
then under IP/DHCP Client i changed interface from ETH1 to VLAN100
and i get the bound message with the ip’s from the local office network via dhcp
so,.. after doing that
there is no internet on the LAN side of the RB952 so i was puzzled
if i got an IP on the WAN side
so looking for answers i read that you need to change the masquerade settings
and the only way i make it to work is to
IP/Firewall/NAT
and change
OUT interface list from WAN to All,
then i need to reboot the router in order for me to have internet on the LAN side and ping 1.1.1.1
if i change the NAT to WAN again, i need to reboot the router in order for that settings to change
and vice versa, the change of the NAT setting only happen after a reboot
is that ok ?
and changing the setting from WAN to All in the interface list setting under IP/Firewall/NAT ?
