VLAN across bridges
Folks, here’s another Q on my journey to understand the VLAN implementation: Suppose there are two bridges, and we want them to share the same VLAN (tagged 10 here). bridge1 could be an ISP delivering a VoIP over VLAN 10, bridge2 an internal network with VoIP phones. Would this be a preferred way to do the trick?
add name=bridge1
add name=bridge2 vlan-filtering=yes
/interface vlan add interface=bridge1 name=vlan10 vlan-id=10
/interface bridge port add bridge=bridge2 frame-types=admit-only-untagged-and-priority-tagged interface=vlan10
/interface bridge vlan
add bridge=bridge1 tagged=bridge2 untagged=vlan10 vlan-ids=10
add bridge=bridge2 tagged=bridge2 untagged=vlan10 vlan-ids=10
No, use one bridge.
The bridges have more than these interfaces and untagged traffic on them is on different subnets. So, I have to route/firewall between them.
Why not use all vlans for subnets, and that way one bridge is much easier to deal with.
Also use firewall rules properly and fewer rules are actually needed.
I am trying to simplify …
Yes, this would be an option; but it meant I had to re-configure the router completely. I just want to “pass” my ISP’s VoIP-VLAN to internal VoIP clients, and I’d prefer to minimize changes to the (complex) router configuration.
You cannot directly share VLANs between bridges - VLAN 10 on bridge 1 and VLAN 10 on bridge 2 are completely independent ethernet / layer 2 networks.
Hm… there is really no way? I guess I could do this with physical cables: Put both VLANs on an ethernet-port and connect the ports with a cable. Not sure if you know what I mean, roughly like this: Create an VLAN-Interface for VLAN 10 at each of the two bridges; then create two new bridges with an ethernet-port and a VLAN-Interface on each. A cable would then connect both ports and also the VLANs on them.
This sounds really weird, and I would think there should be another way to do this…
No i cannot help stubborn horse that refuses to drink clean good water.
That’s why I said directly share. There are numerous bodges - bringing out the VLAN on physical ports and connecting them per your post; abusing a VLAN interface by attaching it to one bridge and including it as a member port of the other (see https://wiki.mikrotik.com/wiki/Manual:Layer2_misconfiguration particularly points 7 & 8 for the potential issues); create a EoIP tunnel within the Mikrotik so one end can be attached to one bridge, and the other end to the second bridge. All very hacky.
Thanks a bunch, useful page! I wasn’t aware of it!
The horse is more interested in learning how to find such water than in drinking it :-).
