Hello
I have a network with 3 vlans and using wireless WDS.
I have an omnitik which has the following configuration:
add name=bridge-vlan20 protocol-mode=none
add name=bridge1 protocol-mode=none
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-onlyn disabled=no frequency=5025 frequency-mode=superchannel \
ht-basic-mcs=mcs-0 ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6 mode=ap-bridge \
radio-name=ZN-SQHP-5-1 rate-set=configured scan-list=5025 ssid=ZN-SQHP-5-1 wds-default-bridge=bridge1 \
wds-mode=dynamic
/interface wireless wds
add disabled=no master-interface=wlan1 name="xx" wds-address=CC:2D:xxxxxxx
add disabled=no master-interface=wlan1 name="xx" wds-address=74:4D:xxxxxxx
add disabled=no master-interface=wlan1 name="xx" wds-address=64:D1:xxxxxxx
/interface vlan
add interface=bridge1 name=vlan20 vlan-id=20
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys \
supplicant-identity=MikroTik
/ip hotspot profile
add bridge=bridge1 interface=wlan1
add bridge=bridge-vlan20 interface=ether5
add bridge=bridge-vlan20 interface=vlan20
add address=172.16.14.10/24 interface=bridge1 network=172.16.14.0
/system identity
set name=ZN-O-5-1
/tool graphing interface
add
I did this because I want to the wlan to stay as a trunk and only ether 5 to be in vlan20.
i am having a problem when the interface 5 which is in vlan 20 is sending or receiving data this data bandwidth is shown on all wds interfaces for example if this interface uses 4 mega bandwidth each wds interface will have 4 mega bandwidth and the wlan interface will reach 20 mega in the tx.
if i disable the ether5 all wds will work fine.
please can you help me what is the reason? May I miss-configure something?
