Hello win,
I have a fairly basic network, port 1 wan.
port 2,3,4,5 in a bridge interface.
I have a data network 192.168.1.0/24
Voip network (vlan: 20) 10.11.12.0/24 associate with interface 2.
I would rather associate the vlan20 with the bridge interface.
But once associate the voice passes pu.
I tried to activate on the bridge vlan filtering.
its gives nothing.
I also try to tagged in vlans in the bridge interface, it doesn’t work.
You have an idea?? Thank you
here is my config:
add name=BR-Data
set [ find default-name=ether1 ] comment=Wan name=WAN speed=100Mbps
set [ find default-name=ether2 ] comment=Trunk speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
/interface vlan
add interface=ether2 name=Vlan-Voix-20 vlan-id=20
add name=jp
add name=ovpn
add name=lan
/ip ipsec profile
add dh-group=modp1024 name=profile-jean nat-traversal=no
/ip ipsec peer
add address=2xx.xxx.xx.xxx/32 name=peer-jean profile=profile-jean
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-256-cbc,aes-128-cbc,3des
add enc-algorithms=3des name=proposal-jean pfs-group=none
add name=Pool-Data ranges=192.168.1.100-192.168.1.150
add name=Pool-Voip ranges=10.11.12.2-10.11.12.254
add name=ovpn ranges=172.16.6.10-172.16.6.200
add address-pool=Pool-Data disabled=no interface=BR-Data lease-time=1h name=
DHCP-Data
add address-pool=Pool-Voip disabled=no interface=Vlan-Voix-20 lease-time=2d
name=DHCP-Voix
/ppp profile
add change-tcp-mss=yes local-address=172.16.6.1 name=maison remote-address=
ovpn use-compression=no use-mpls=no
add dns-server=172.16.6.1 local-address=192.168.1.1 name=OVPN-Client
remote-address=Pool-Data
add change-tcp-mss=yes name=default_ovpn use-compression=no use-encryption=
yes use-mpls=no
/snmp community
set [ find default=yes ] addresses=192.168.1.0/24 write-access=yes
/system logging action
add disk-file-name=Userlog name=userlog target=disk
add disk-file-name=ATTACK name=ATTACK target=disk
/user group
set full policy=“local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas
sword,web,sniff,sensitive,api,romon,dude,tikapp”
/dude
set enabled=yes
add bridge=BR-Data interface=ether2
add bridge=BR-Data interface=ether3
add bridge=BR-Data interface=ether4
add bridge=BR-Data interface=ether5
set discover-interface-list=*2000011
/interface detect-internet
set detect-interface-list=all
add independent-learning=no ports=ether5 switch=switch1 vlan-id=200
/interface l2tp-server server
set allow-fast-path=yes default-profile=default enabled=yes use-ipsec=yes
add interface=BR-Data list=lan
/interface ovpn-server server
set certificate=OvpnServer cipher=aes256 default-profile=default_ovpn
enabled=yes keepalive-timeout=30 require-client-certificate=yes
/interface sstp-server server
set default-profile=default-encryption
/ip accounting
set account-local-traffic=yes enabled=yes
/ip accounting web-access
set accessible-via-web=yes
add address=192.168.1.1/24 interface=BR-Data network=192.168.1.0
add address=10.11.12.1/24 interface=Vlan-Voix-20 network=10.11.12.0
add address=10.11.50.1/24 interface=BR-Data network=10.11.50.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1m
add address=10.11.12.0/24 dns-server=192.168.1.1 domain=Maison.local gateway=
10.11.12.1 netmask=24
add address=192.168.1.0/24 dns-server=192.168.1.11,192.168.1.1 domain=
Maison.local gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.250 name=clo
/ip firewall address-list
add address=172.16.6.0/24 list=openvpn
add action=jump chain=input disabled=yes in-interface=WAN jump-target=
ch-in-wan
add action=accept chain=ch-in-wan comment=“Permit SAFE Router” in-interface=
WAN src-address-list=Safe
add action=accept chain=forward connection-nat-state=dstnat
add action=accept chain=forward disabled=yes dst-address=192.168.4.0/23
src-address=10.11.50.0/24
add action=accept chain=ch-in-wan disabled=yes in-interface=WAN protocol=
ipsec-esp
add action=accept chain=input comment=“Allow OpenVPN” dst-port=1194 protocol=
tcp
add action=accept chain=ch-in-wan comment=“#1 DNS” connection-state=
established,related protocol=udp src-port=53
add action=accept chain=ch-in-wan comment=“#2 NTP” connection-state=
established,related protocol=udp src-port=123
add action=accept chain=ch-in-wan comment=“Allow L2TP/IPSec” disabled=yes
dst-port=1701,500,4500 protocol=udp
add action=add-src-to-address-list address-list=BLACKLIST
address-list-timeout=30m chain=ch-in-wan comment=“#3 PSD” protocol=tcp
psd=21,3s,3,1
address-list-timeout=30m chain=ch-in-wan comment=“#4 telnet, ssh”
dst-port=22,23 protocol=tcp
add action=drop chain=ch-in-wan comment=“#5 BLACKLIST” disabled=yes log=yes
log-prefix=“BLACKLIST===” src-address-list=BLACKLIST
add action=accept chain=ch-in-wan comment=“echo requests” icmp-options=8:0
protocol=icmp
add action=accept chain=ch-in-wan comment=“#6 echo reply” icmp-options=0:0
protocol=icmp
add action=drop chain=ch-in-wan comment=“#7 http(s)” dst-port=80,443,8080
log=yes log-prefix=“HTTP(S)===” protocol=tcp
add action=accept chain=ch-in-wan comment=“#8 established, related”
add action=drop chain=ch-in-wan comment=“#9 Catch-all” log=yes log-prefix=
“CATCH-ALL===”
add action=return chain=ch-in-wan comment=“#10 return”
add action=dst-nat chain=dstnat comment=“Serveur FTP” disabled=yes
dst-address-list=Safe dst-port=21 in-interface=WAN protocol=tcp
to-addresses=192.168.1.250 to-ports=21
add action=masquerade chain=srcnat comment=“defconf: masquerade”
out-interface-list=*2000010
add action=accept chain=srcnat comment=“Regle IPSEC Mirazed” dst-address=
192.168.4.0/23 src-address=10.11.50.0/24
add action=masquerade chain=srcnat comment=“Harpin Nat” disabled=yes
dst-address=!66.130.190.20 out-interface-list=*2000010 src-address=
192.168.1.0/24
add action=dst-nat chain=dstnat disabled=yes dst-address=66.130.190.20
dst-address-type=local dst-port=80 protocol=tcp to-addresses=
192.168.1.5 to-ports=80
/ip firewall raw
add action=drop chain=prerouting comment=“Drop BLACKLIST” src-address-list=
BLACKLIST
/ip firewall service-port
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes ports=5060
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/ip service
set telnet disabled=yes
set ftp disabled=yes port=2100
set ssh disabled=yes
set www-ssl disabled=no
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ppp secret
/snmp
set enabled=yes trap-generators=interfaces trap-interfaces=all trap-version=2
/system clock
set time-zone-name=America/Toronto
/system identity
set name=CAMfdsafdsonhfhfsdaf
/system logging
add action=userlog topics=account
/system note
set show-at-login=no
/system package update
set channel=testing
/system routerboard settings
Firmware upgraded successfully, please reboot for changes to take effect!
set silent-boot=yes
/system watchdog
set watchdog-timer=no
/tool bandwidth-server
set authenticate=no enabled=no
